Venom, While it would be awesome having adjustable coilovers, I think having a better driveline esp with a front LSD & locking centre makes up for lack of articulation. Of course, it would be nice having both lol
It compensates to an extent, yes. It does and never will fully compensate for it. It does not substitute good suspension. Jump on a 4WD forum and tell people front and rear lockers pretty much negates the need for good suspension. Yes you could. Yes it is better than completely stock. No, the most gold plated driveline does and nevery will substitute good suspension. To talk about it like they are mutually interchangeable is very a very narrow perspective. It's just as narrow to try to compare them, just as you wouldn't necessarilly compare a set of lockers to good suspension. They are very much mutually beneficial and necessary modifications.
A fair price comparison on LSDs vs. custom coil overs would be to compare brand new LSD units, which start around $1100 each. $1500 for a new Subaru torsen unit. I paid pretty much exactly 2,500 for my front and rear units, another $1,000 for the centre DCCD and controller. Plus another $1,000 or so for the gearbox to be built, 1.59 L/R etc. It is, all things said and done.. something in the region of a $3,500 driveline (probably more). Yeah less if you DIY and buy second hand. Probably more than what I paid if you don't do any DIY. My point? $2,500 is not ridiculous. You are actually getting something for that extra money.
For people interested in less extreme modifications some custom coil overs in fact make more sense. No strut blocks. No driveline modifcations. You could in fact daily drive at stock height. Very simple, very effective. A **** load better than stock shocks, springs and a spacer.
Basically, the coil overs seem only available for some models. Apparently, those that would fit mine are meant for lowering, making price a moot point for me.
Dude, yes off the shelf are virtually all tarmac orientated and for lowering. Hotbits is probably the only reasonable place you will get a custom set made. They have to be custom. You will not get an off the shelf solution unless it is rally suspension, which is expensive and unsuitable.
Coil overs are not "lowering" only. It is just a term for a type of strut. Coil overs are used in rally, dakar, hard core off-roading etc.
