Ratbag
- Jan 1, 2012
- 7,483
- Bayside, Melbourne, Vic
- MY06, MY10
- Forester SG & SH
- 5MT/DR & 4EAT Sports
^ I already have a lot of detail shots uploaded to my web site. I will have another look at them and see what's missing. Shouldn't be too many that I've missed, but there will be some when looked at from your perspective.
Your trailer is also going to be different as a result of ending up under a different kind of tent.
Correct me if I'm wrong, but as I now understand it, your RTT folds out to the side and you sleep crosswise, i.e. at right angles to the length of the car/trailer. If so, this will also govern the design of the trailer.
Which side does it fold out to, D/S or P/S?
[EDIT]
Most are already uploaded. Just need to duplicate the relevant ones into a coherent set in another album.
Need to take a few detail shots of the chassis and springs from underneath.
I have been thinking about how to lift your RTT to an appropriate height. Perhaps either a scissor lift ( X ) or an elbow lift ( < > ) with slide locks over the pivot points. The lift process could be assisted by 4 appropriate and appropriately placed gas struts. The pressure, length and placement of these needs very careful consideration. It took three goes and re-gassing to get mine right!
Any method of doing this requires that you can seal off the trailer tub from both the elements and casual thievery! So I suggest that you keep the two design aspects (relatively) separate. The lid can also serve as table space when camped. Perhaps simple drop-down canvas sides that are attached to the underside of the base board of the RTT would fulfill this requirement. These could be in 3 (or 4) separate sections, joined as desired with broad Velcro stripping. This is how the main annex roof is joined to my CT tent body, and the entire sun room annex has 3 individual walls, a trailer rear infill panel and a floor that can be assembled like Lego as required or desired.
[end edit]
[EDIT]
[end edit]
