casperfromholland
- Sep 5, 2011
- 267
- Amsterdam Holland
- 1999
- forester sf
- manual 5speed 4.44 end h/l 1.59
Hi guys, i would like to hear your opinion.
At first, my fozzy is my dailydriver and i like to go off-road with it Together with the so called real 4x4's. I like the way my foz drives on the tarmac but it needs some extra prep for the offroad work. I thought long to buy a cherokee or a terano but here in holland you pay roadtax according to the weight of the car. The heavier the car the more you pay and the difference is huge. So I decided to keep my foz and make it better offroad.
Current mods are 4cm lift rear, 2 cm front. Lifted kings, 205-75-15 tyres on VW rims.
Offroad in holland means, small hills, sand or mud with deep ruts. Making passing those ruts a bit easier i want to switch to 225-75-15 tyres or even 235 if it doesn't rub. I also want to change the gearing. My '99 foz has a gen 2 engine and tranny. As i understood a gen 1 box does fit on a gen 2, 2.0l engine. So i want to switch to a gen 1 tranny, a 4.44 final drive from a WRX together with the LSD rear diff. Also i want to switch the low gearing to 1.59 from a early 1.6 impreza. This gearbox will be professional build by a builder who makes normaly boxes for race and rally cars.
The big tyres does compensate the 4.44. In fact with 225 75 15 tyres the engine will make just as much rpm at 100km p/h as stock. And the 1.59 will make offroading a bit easier. A dccd is too expensive at the moment so i won't change that. A usa company offers wheel adapters from 5x 100 to 5x 139.5. Then i can use rims from a daihatsu or suzuki with a much bigger offset so no rubbing issues with the rear shocks.
What are you thoughts about this?
