El_Freddo
- Aug 11, 2008
- 2,400
- Bridgewater, Vic
- 1988, 1990
- EJ22'd L series; Targa Brumby
- Locking FT4wd 5spd Manual, 4.111:1 diff w 1.59:1 low range & front OBX LSD ;)
All I know is locked=good :biggrin: wheel spin=bad![]()
That all depends on whether or not the wheel spin is all four while sliding sideways or one hanging in the air...
Not many of you may know, but there are already auto lockers out there for the subaru but they're rarer than hen's teeth! I know of one member here who has one in a PT4wd subi - it works very well offroad.
Airlocker - that would be the ulitmate! But with the space restrictions inside the subi rear diff it is pretty much deemed impossible to do.
The rear diff of the subaru has not changed greatly - the only thing that has changed, as previously mentioned, is the way the rear shafts connect to the diff - newer subi's are a female "stub axle" in that the drive shaft actually goes into the diff, I think its held there by a circlip. The older subi's have a stub axle that the drive shaft mounts on to. Don't ask me why subi went this way as I cannot see a good reason for it.
Over on Ausubi we've also had the debate about the driving characteristics of the AWD with an auto locker in the rear - most reckon it would be more dangerous through corners in that you would not be able to start accelerating out of or through the corner when you usually do, you have to do it later otherwise you'll get some oversteer - that said, no one was a test dummy for it. Also, when offroad you will be able to spin a front wheel much easier when the rear has all the traction, such as when climbing a steep hill.
I guess it all comes down to having some one with an auto locker in their AWD subi to give us an un-biased report on its driving characteristics and its offroading abilities.
We'll always be toying with this - for you guys with AWD, the real answer won't arrive until you can lock your centre diff (manual) and we can get our hands on an air locker or the like that we can control.
