I've been recently asked again what mods have I made, so here they are as copied from SF.ORG and needs updating (in process):
Mods to my Foz
In case of interest these are the mods I’ve made to my MY03 XS to prepare it for outback travel and club events plus other “enhancements”. (I’ve installed everything myself except the tyres, new struts & rear springs and muffler):
SubaXtreme bull-bar, rear bar with carriers, sump guard and 40mm lift kit. Better approach / departure angle, ground clearance and belly protection.
Added snorkel – having experienced the nasty effects of taking in water, i.e. hydro-locking resulting in a blown motor, this was a necessity before attempting the Cape York trip in 2005. I decided to not go through the fender and instead fitted a Mazda Bravo snorkel on top of the LHS fender with the inlet through the plastic cover of the air dam in front of the windscreen. In really dusty conditions I use a finer-filter “Droopy” in the snorkel head. (Droopy is an oiled foam cone-shaped filter)
Extended front air breathers and added filters to keep out water and dust (transmission case, oil pump housing). Added rear diff breather.
Tranny cooler.
Added dual battery system (for fridge/freezer) also in preparation for Cape York in 2005. I was very happy with the 60 litre Evakool ice box for short trips of 2-4 days but a fridge was very necessary for the long trips where I use the Evakool 49 litre as a freezer and use the ice box for daily storage and cycle ice bottles though the freezer. (2014 - I now also have a 110L Evakool fridge/freezer for the Triton)
Removed the OEM struts (incl self-levelling rear) and replaced with KYB Excel-G and raised King springs. This was after a self-levelling strut failed on the Cape York trip.
Had rear trailing arm blocks made: https://offroadsubarus.com/showthread.php?t=1162
Subsequently had custom struts made: https://offroadsubarus.com/showthread.php?t=953
Replaced tyres with Yokohama Geolander All Terrain +II 21565R16. Then after losing 6 of 11 Yokos to side-wall damage changed to 15” x 6” Speedy Sorroco II wheels with +50mm offset and 21575R15 B F Goodrich AT Traction t/a’s. The wheel change required grinding down the front brake callipers for clearance. The spare wheel does not now sit properly in the wheel well; even when deflated.
Replaced exhaust from the last flange back (axle-back) to include a new, lower profile Lukey muffler to aid departure angle and tuck the muffler up behind the SubaXtreme bar. In 2014 replaced from headers back with new free-flow system.
Off-Road Systems designed and installed a set of rear drawers. I added 2 x 4WD Warehouse fridge slides “Ezi-Slide” later.
https://offroadsubarus.com/showthread.php?t=574
Added circuit to isolate radiator fans for water crossings.
Centre diff lock circuit. Fools the TCM into a 50/50 distribution of power front / rear
Substituted fog lights with Hella Comet FF 50 (because of their low profile). Added Narva Ultima Combination Driving Lamp Kit 175mm dia. One Broad Beam, One Pencil Beam.
Sealed up the fog lights with silicone and added breather tubes extending into the engine bay (because the fogs took on water at every river / creek crossing)
UHF CB and antenna. A GME remote head unit which I installed in the ash-tray. (So unplug the mic, close the lid and it’s not visible.) The base unit sits vertically behind the centre console. Antenna is 2 part and gives 6 DB std; 9 DB extended. Replaced antenna with GME GME AE4018K1: https://offroadsubarus.com/showthread.php?t=761
Cell phone (GSM) in-car kit and high gain antenna. (2014 - still there but no longer used; I need to pull it out)
Covered headlights, driving lights and fog lights with 3M protective skin.
Installed a marine type compass that has back lighting. (Has compensating adjustments for electrical interference)
Set-up for Thule roof rack and roof box. (Transferred from MY‘97 Outback)
In 2007 got a Columbus roof-top camper to which I added solar panels in 2014: https://offroadsubarus.com/showthread.php?t=5714
Electronic Rust Prevention System (Capacitive Coupler type).
Jaycar Super Tweeters.
Sealed up rear flow-through air vents located on each side of the car in behind the bumper bar to prevent the ingress of water and dust.
Added flexible mud flaps
Added trailer electrical plug.
Removable radiator mesh to stop bugs
Dust filter in cabin. This is a standard Subie part and is located behind the glove-box but is not supplied as standard
Added rear view camera so I could see when both fridge and ice boxes are carried in the back.
