^ Yup ...
:iconwink:.
For all that some here have had very ordinary experiences with the SubaXtreme cast alloy sump guard, I was suitably impressed that I was able to put a block of wood on mine and belt the hell out of it with the back of a small Canadian block splitter without apparently cracking or otherwise damaging it!
Mine was s/h, and had taken a few mighty thumps that had bent it as much as ~1" out of shape - maybe a bit more in places, specially down the middle.
Using the above process, I straightened it out by about this much, one part at a time (leading edge where it slopes down from the from cross-member; and the flat part under the engine), and then went to work on the 'wings', bending them down and out away from the headers/exhaust pipe shields. All parts of the shape required multiple hits to get them straight, one small area at a time.
This amounts to belting the crap out of it with a small sledge hammer with all the force I could muster using one hand (albeit with a small block of pine, about 4x2x2.5", between the hammer and the guard, with the guard supported flat on the paving on the other side).
This is a pretty massive amount of force to apply to anything IMO. It assured me that this guard will probably take anything I am likely to do it. Even if it does break up and protects the sump while doing so, it will have served me well :biggrin:. I doubt
very much that I could apply this amount of force to my sump without completely buggering the engine ...
