Douglas Ferrier
My experience in using slotted rotors (front only) with appropriate pads has been a far superior outcome to the foz original rotors/disks.
To me it seems subaru underestimated the demands on the foz brakes, hence it is quite common to see the "not really satisfied" notes on foz brakes on many forums and motoring literature.
When comparing wear rates it is important to start calculating vehicle kinetic energy (linear and rotational) that needs to get bled off as heat through the brakes and the relative surface areas available to the friction surfaces, (relative pad thickness and surface area).
I made some quick back of the envelope calculations when I was fed up with the stock rotors needing skimming regularly and the pads being chewed through 3 to 4 times faster than I had experienced in other cars and at that time it made it pretty clear to me that the car was about 40 to 50% greater in mass than the other cars I had been use to and this means about an equivalent greater amount of heat energy bleed during each braking op and this was being done through surface areas that were only in the order of 10% larger thus explaining the less than happy outcome compared with previous experiences.
Before moving to the slotted rotors and pad combination I had several brake experts say nah you only need it for racing, the price variance was minor so I gave it a shot and the solution has come up trumps for decreasing brake wear while retaining performance.
Pad wear and rotor wear decreased significantly while improving braking feel and retention of feel during multiple stops.
Hence I think what I am saying is ratbag is correct the right engineering for the right job.
Keep in mind that where you use the car also impacts significantly on wear rate and perceived performance.
Comment: Melbourne traffic is a killer these days compared to 10 years ago, so the same routes take longer and induce much higher wear rates than ever before, freeways you use to be able to use cruise control on are now impossible and have you braking, accelerating 2 or 3 times every km due to traffic volumes being so high. The civic we have is now chewing brakes more rapidly than in years gone by, same setup same pads etc simply more use and I suspect more heavy brake events as it seems there are far more random acts of madness on the road than in years gone by.
So to summarise moving to slotted (vented rotors) with appropriate pads has vastly improved my foz braking experience, thus I would say is a better matching engineering solution than what came of the factory for this vehicle.
As Ratbag has alluded to -brakes may not save you, compromising on a system critical element is a dubious choice ...
And nothing is perfect, this being my first subaru it has impressed me overall (with the brakes being the only real disappointment - a solution to which I found at very reasonable cost so can not really complain given the mass consumer market it is trying to each)
Doug
Doug
