guzzla
Why?!!I actually prefer front discs and rear drums ...
Why?!!
Must disagree about some from my experience.Effectiveness, cost, maintenance, reliability, losing additional unsprung weight, etc. ...
They haven't used drums in racing for many decades, a pretty good indicator
186 HR Holden wagon, 245 2-barrel VG Valiant sedan (wow that had some power!) and rear axel tramp under brakes and total fade after a couple of seconds of heavy brake application are frightening memories that no drive should have to experience. Gee I used to scare myself ****less in those cars lol. They both had drums at the front too. Arghhhhhh....
I think Ratbag is comparing drums not with discs but with opening the door and dragging his feet on the ground
:rotfl::rotfl::rotfl:
RB, you've opened a can of worms! :rotfl:
This is KiwiFoz's thread. Might be an idea to move these posts to a Drum V Disc thread
I think Ratbag is comparing drums not with discs but with opening the door and dragging his feet on the ground.
It is all but impossible to have brake fade on rear brakes, precisely because they contribute almost nothing to braking; but heaps to stability during braking ...
With towing heavy objects, yes. That's why the LC had 8 leading shoes instead of a single pair of leading/trailing shoes at the back. Even with a braked tandem axle trailer weighing a couple of tonnes, the rear brakes suddenly become important for braking effort of the whole system, and for the prime mover in particular. With many (most?) modern cars having extremely small disc brakes at the rear, it is no wonder that many people towing (relatively) light trailers need brakes on those trailers.
The brakes on my Foz were done less than a year before I bought it, which is great. However, NONE of the cars in our family have ever had to have discs machined - I think this is probably due to the fact that we all use engine braking on downhills to save brake wear, something that is sadly becoming less common as more and more people drive autos.As for maintenance. Hands up how often people have had to have their discs skimmed or outright machined? Right ... It's a commonplace occurrence.
I have had to have drums machined twice. Once on the fronts only (Mini); once all round (LC) when I did a complete brake overhaul at around 240,000 miles (~386,000 Kms).
I agree. My mum's Sirion has rear discs and they work - but when you stand on the brakes, there's a definite pitch toward the front, more so than my Foz.I am not saying that drum brakes are superior to discs, specially not for modern consumer level cars; specially not for front brakes.
Just that they aren't the rubbish they are made out to be, either.
To a point. They're good on tarmac, but I've almost had a few crashes on gravel/mud due to them, where they have the opposite effect to that desired, of prolonging understeer and preventing the development of an easily controlled skid. I've done a driving course in which we were taught impulse braking on gravel, and I prefer this method for gravel - but on tarmac I like the ABS, it does a better job than I can.I certainly wish that my Forester did not have ABS brakes ... Great safety item at a population statistic level - high potential to be rubbish and dangerous if you can actually drive competently. I learned impulse braking before I even got my licence. The technique is still useful for "disabling" the ABS in emergent situations ...
The rear discs and pads on both the SG and SH have about 1/3 the contact area of the front brakes. Both cars brake well. However, neither they, nor any other modern cars, brake from 60 mph in significantly less distance than did my Morris 1100, with discs at the front, and drums at the rear ...
Interesting - but then again, the area of the brakes on the Foz will be significantly greater than that of the brakes on the Morris, so that the overall front:rear braking ratio and weight:clamp force ratios are similar between the two vehicles.
You know that is one of the really great things about the brakes on my SG Foz. At 259,000km the rear discs and pads are original. The original front pads were replaced at the 237,500km service when the rotors were machined, not because there was any warp or shudder but they said that with new pads that they always machine them. I just wish my Foz's brakes had the stopping power and the feel of my Golf's brakes. I bet they don't last as long as the Foz's though.
We have been there before. I really don't consider that a couple of feet difference in braking distance between that of a small, sports hatch and a general purpose SUV is significant. I also don't place much store by personal assessments of the "feel" of brakes. According to Wheels, the Audi Quattro bi-turbo brakes "felt" better than those of the twin turbo Liberty they tested it against, but it didn't stop any better, or in less distance ...
If I get 100,000 Kms out of a set of pads, but you get 250,000+ Kms out of yours, then either your pads are made out of some miraculous material that's different from mine, or I drive much more vigorously than you purport to. AND I don't drive on the brakes. Never have.
And what do really big trucks use ... ?
The 186 HR had completely useless discs at the front. Tiny little things that would fade at the merest hint of serious braking. The one's on my father's faded coming down from the Lamington Plateau under moderate braking, and the 2 speed slush box didn't help at all. As you say, scared ****less hitting the corner at the bottom at over 80 mph, with no brakes and lousy handling for good measure!
So you use an example of under engineered disc brakes as an example that disc brakes are no good. I have these discs on the front of my WRX, what sort of drums would bolt on that would be as effective as these?
Harold Dvoretsky asked the rhetorical question, with answer: "Why did they call it the Valiant? Perhaps because that's what you had to be to drive one." A
My cousin's Pontiac GTO 400 made the Valiant's slant six look sick for sheer power and (straight line) performance. It had 200 sq. in. of power assisted drum brakes shrug: ). In a single stop from around 80 mph, the brakes had completely faded by the time the car was doing around 50 mph. Crappy design, and appallingly inadequate implementation for a heavy powerful car. An E-Type Jag had 361 (or 461?) sq. in. swept area of power assisted discs. Inboard at the rear to keep the unsprung weight down. It stopped OK! As did the all drums Silver Cloud RR!
I had rear drums on my XA GT Falcon when I first bought it. A spirited drive along with another car saw my rear brakes completely fade out, with smoke billowing from them. A switch to rear discs and I NEVER had that problem again.
Many American based cars also had leading/trailing shoes on the front. These are easily distinguished. Leading shoes have a slave cylinder for each shoe in each drum, so that precise adjustment is not so critical to performance. Leading/trailing shoes have one slave cylinder for the pair of shoes, so precise adjustment becomes extremely critical.
Early modern consumer cars with 4 wheel discs (mid-1990s) often had the problem that one (or more) of the pistons would seize on one or both of the rear wheels. This did nothing whatsoever for vehicle stability under braking - quite the contrary ... . Swinging caliper design has all but abolished this problem. However, the tiny size of the rear pads should instantly inform one of how much braking effect the rear brakes have ...
You should never need to machine discs. It is almost always a waste of money. There is no issue with the disc other than there being a build up of material on it, generally due to pad to disc incompatibility and with the way the car is being driven.
I had to replace the rotors on the Camry at about 90,000 Kms ...
They were worn such that they could not be machined. Apparently the OEM pads were harder than the OEM rotors ...
My Forester has done 232,000kms on the original pads and discs, with almost no lip, no cracks and no so called warping.
But they still are more maintenance, and more difficult to work on, and they fade. They have, quite rightly, been consigned in all but the very small cars to history, where they belong.
I am a big fan of ABS and while I learnt to drive on a non ABS car, I am pleased to have it. While my XA Falcon stopped admirably well when confronted with an oncoming road train, especially considering the drivers side wheels were in the dirt
My WRX brakes pretty well! Not forgetting that in most one off applications, it is overall tyre grip and weight that have a bigger determination of braking distance
I would also suggest that the Renault 16 (mid 1960s) would probably out-brake them all. It did have 4 wheel discs, and it was the one thing it was really, really good at ... apart from falling to bits ... :biggrin: :lol:.
