taza
My convereted EJ25 Foresters has some pinging. When I strippes the motor for the head gasket job a month ago there was no signs of detonation damage.
Im running the standard computer qith Ej25 manifold and injectors.
Since building this motor and having it in the foz (14months) it has always been ran on BP98 fuel. Except for an odd occurance once or twice.
I noticed today that while under slight load (60kmhr in 3rd gear), up hill there was slught pinging.
I tried running the car on octane 91 for the first time 2 weeks ago. While the car ran very well, with very little difference in performance it detonated like no tomorrow. Even when driving carefully.
The standard ecu is not programmable at all. Infact my particular one is a completely sealed unit.
Non the less I need more fuel! I was going to uograde trom the standard fuel pump to a Walbro 255. Which flows at 250l per min. While the standard one runs at 180l per min.
However if I uograde the fuel pump will I see an increase in pressure after the fuel pressure regulator? So at the injectors. Or will I still be limites to around 43psi at idle?
If I upgrade the regualtor and not the pump, this might be adequate. However I am unsure if I should go to an adjustable fpr or rising rate fpr. The rrfps adjusts 10psi with ever psi in vacuum.
Last option is to upgrade the injectors to 280cc from the standard 220cc(ej25).
My goal is to run octane 91 fuel comfortably without detonation.
Thoughts?
Thoughts?
