HR/LR gear ratio table for the SF & SG 5MT/DR gearboxes
Gidday Folks
Some comparative figures for the SF and SG gear ratios and LR gear sets in tabular form, comparing the Kmh/1000 rpm for HR/LR in each gear in stock cars.
Click on
this link to download a legible/printable version ...
I have spent much of today researching and putting this info together in an Excel spreadsheet, then working out the formulae to calculate out all the kmh/1000 rpm in each gear for both HR and LR. The Impreza is in there for a comparison of its gear ratios. The series I SG is there because at one point I mistakenly though that it had a different FD ratio - soon corrected, and I couldn't be bothered removing it and re-doing the Excel to PDF to JPG conversion so that I could upload and display the file.
If I have screwed up any of the figures, please tell me. I am not really all that well today ...
I have used the figures from the various Oz Subaru advertising brochures and the rolling circumference of the various tyres from
the tyre calculator here.
Regardless of what people might think on this topic, it looks as if the facts speak for themselves.
I cannot see engine braking being greatly changed by there being a 1.4 kmh/1000 rpm difference in speed between the 2.0L engine with 1.447:1 LR and the 2.5L engine with 1.196:1 LR when both are in 1st/LR.
In fact, perhaps the larger capacity engines should/would have the same or slightly more engine braking as a result of their greater capacity. Since engine braking will be proportional to torque, this
should be the case. I am not making a case for this, merely pointing out that one could be made for this being the case in a throttle closed situation.
It is also not the case that I am saying that I wouldn't rather have had a 1.25x:1 or even a 1.3x:1 LR in our SG cars. I would have preferred that myself. However, I suspect that going to 1.447:1 would put too much strain on the whole gearbox assembly when behind (particularly) the EJ-253 donk. I am speaking in general terms here.
While Taza's car is using the EJ-251, it has also had it's piggy-back ECU tuned. This will give it a bit more torque at lower revs than a standard EJ-251. It has been suggested that the EJ-253 could also benefit from having an after-market tune done. Guzzla has reported that this made a big difference to his MY07 XT, and I can't see it being different for the N/A donk. This might be a better alternative than changing the LR gear set. Just FWIW.
One simply has to realise that these cars are not designed for our specific use, and it is more than a little counter-productive for Subaru to be repairing every second (and third, and fourth ... ) car they sell because some nitwit puts it into 1st/LR and does a launch on dry bitumen ...
. I have actually done this (carefully ... ) in my car, and while it gets under way in a hurry, it isn't hard to see how one could wreck the tranny doing it a lot ...
The design of any car is always going to be a question of balance. It is easy to see what Subaru have done with the LR gearing, as I have said before. As the torque and capacity of the engines increased from the L series through to the cars that most of us drive (SF/SG/SH series I), Subaru has dropped the LR ratio to match (in reverse) the increase in torque of the engines.
My friend with the Suzuki Grand Vitara (2.7L V6) reckons that the Zook is probably somewhat more indestructible than Roo2. I tend to agree with his assessment. However, he also reckons that in every other respect the Forester is a better car. More comfortable; quieter; better handling; more poke in LR ...
; better brakes. The Zook is also about as big as SWMBO's SH ...
The chart also shows the huge gap between 4th and 5th HR that we have been discussing.
