- Dec 3, 2012
- 766
- Perth Western Australia
- 1999
- Forester
- 5MT
Have you worked out final drives in each configuration? eg, is 2nd low higher or lower than 1st high?
2nd low is marginally higher than 1st high but with the 4.44s is marginally lower than standard sf 1st high.
Last weekend was another big gearbox weekend. Pulled the box out and pulled it apart. Checked over everything and changed the bearing on the lower transfer gear. Also checked the front diff setup. I also installed the low range and 1st gear oil feed whilst I was at it as I had completely forgotten about that on the first assembly. Put it all back together and put it back in the car. Not bad for 2 days work. I havent been able to tell it it was making any noise until today though as I had a front wheel bearing gone which was making a hell of a noise. Now that the wheel bearing is fixed I am happy to say it sounds nice and quiet now
On another note I love the new ratios in this gearbox with the 4.44s, perfectly suited to my gutless motor and with the taller 5th there is no real change in freeway rpm. Fuel efficiency, not sure about yet as I cant get my speedo corrector to work for some reason, just wont pick up the input signal from the gearbox no matter what I do. The other thing about this box which is a huge improvement is the 35:65 torque split, so much fun on and off road.
I still haven't had a good chance to test the box offroad but I am expecting great things with the twin LSDs and lockable centre.
Finally a few pics from the build. Completely forgot to take photos for most of it though...
Making the replacement coil for the centre diff
4.44 gear almost completely shaved, a small amount more came off after this.
And finally everything assembled in one half of the case
