The 0.78 5th from the L series box would be a good option but I am not sure if it is compatible. The ratios from 3rd to 5th from the L series box would actually be a good conversion to compensate for the taller final drive.
AFAIK the L series 5th gear is not interchangeable with the EJ layshaft. And the 3rd to 5th of the L box I don't think will interchange unless you've got one of the harder to find L AWD boxes where you can use the whole gearset from that box.
I disagree, a locker allows you to slow down and drive more carefully on the same terrain, crawl instead of bash your way through.
Too right - or as we witnessed last weekend to allow you to go foot to the floor and know all four wheels are going to do the same thing regardless of the surface traction
I had a fault recently with my DCCD controller in my WRX, whereby the auto function failed and I had to use full manual control. Just by locking the centre diff, I could hardly turn the car and I had to manhandle the thing just to swerve through witches hats. The car had fantastic grip, but the car would just not turn. So think what a locked front diff would do to your steering.
On bitumen I can see how that would happen. On a loose surface it'll be different. Also with a manual locker up front you can turn it on and off as needed, which is exactly why I'd want one in my gearbox (and in the rear too!).
We're starting to blur the lines between why we want lockers as Dedman is talking about offroading with lockers - you just can't go past them for ultimate traction! No two ways about it.
The next decision is what front diff to go for. Helical or plated. I am currently thinking helical as it is less noticeable in a DD but I am not sure how well they actually perform. Does any one know what the max torque bias capable from the different subaru 'torsen' style LSDs?
No idea on the torque bias but my cheap OBX unit does the job well, even more so when pushed. Can't go past a traction device up front!
Rally, Venom and Elfreddo swear by their. Combine with something tight in the rear and something in the centre it'll help.
So with a clutch type in the front you hwve to keep splitting and pulling apart the gesrbox to adjust it every so often. Helical/torsion is maintenence free!
Yeah as Taza says, I'm very happy with mine. I do wish I got the factory subaru unit as they started popping up on fleabay for a hundred more than what I paid for the OBX unit. But the OBX is doing a good job and it doesn't make any noise. It does need to have the wheel without traction *just* touching the ground to be of use though.
Venom no longer runs a helical front diff - hasn't for some time now.
I've still only got an open diff in the rear and it's not much of a hinderance in the grand scheme of things. I'll happily wait for a rear locker to appear - then it'll be stepping things up a whole new level in offroad ability!
As for your build Dedman - go the 4.44, you won't regret it even with the extra work required to fit the L series low range in there
