taza
Well the way I see it is heat rises. When your driving along a scoop will force air into the engine bay ontop of the manifold. However around that area you will still have hot air rising.
It may push some hot air out under neath but I feel that it won't make a dramatic difference.
I'd be changing the coolant to start off with. Doing the trans oil cooler like Kevin did in an auto and making some vents in the sumpguard.
An always on switch will help too ss Nachaluva suggested. At work when we gas up a car, mainly cars with viscous fans not thermo fans we use a water spray bottle to wet the condenser. This brings the pressures down in the a/c system which then produces cooler vent temps in the car. This will bring the radiator temps down.
A simple jet washer system could be effective like how your windscreen wipers work.
I plan to try this as my aircon struggles to get down to 10degrees on a 40 degree day.
