I skimmed through and did see this mentioned, but when my fuel milage starts to drop, it's because of a dirty MAF sensor. Not sure of the setup on your car, but on mine, the MAF "bulb" was completely caked with crud. Not to mention, I was getting boost cuts because the MAF was improperly reading the intake, causing the car to run lean. I also noticed a fuel economy drop as well. Thought I had something majorly wrong, but a tip from a local Subaru Master Tech of 17 years had me replace it and it's been perfect (tried cleaning it, but that didn't fix it).
Not sure if this helps, but it's worth a shot if you have an MAF and not a MAP sensor.
