Kevin
- Jul 28, 2008
- 7,158
- Sydney, Oz
- MY'03
- Forester
- A/T
Prices are going up by the sounds of things. I guess that's Covid for you.MY06 FX for $4500 w/ 250,000 Ks on the clock
I'm in an MY09 Forester 5sp Manual with Dual Range. When we got in a bit of trouble, and I needed to give it some juice, the clutch would come out smoking and smelling. Is this unavoidable or just poor handling on my part?
Assuming you use the manual gearbox way of clearing obstacles, a new clutch is prone to slipping because some clutch material has to bed-in to the flywheel for the system to eliminate slippage as much as possible. It's similar to the bedding-in of new brakes. Pad material has to be embedded onto the rotors for maximum efficiency.The clutch is also really fresh. We are talking like a few weeks old. Could this contribute to the smell?
I had the same instance before but with a different vehicle, a FWD Toyota Scepter, and a brand new clutch. I was reversing up the driveway and my left foot was on the footrest, but then the clutch slipped when the rear left tyre got stuck, giving out that foul smell. After that event, I never had any sort of slippage again and I could feel the efficiency of the clutch meet. After that initial slippage, I might have instantly bed-in the clutch material to the flywheel.This has since disappeared so I assumed that it was, perhaps, an outer coating on the pressure plate, since worn/burnt off. Yours could well be the same.
Good to know, my experience was similar - reversing up a steep incline my back left tyre got stuck and the clutch has obviously begun slipping. I was concerned about the smell knowing that the clutch was only recently replaced. So, this gives me a lot of confidence. Thank you @ABFoz and @atedayAssuming you use the manual gearbox way of clearing obstacles, a new clutch is prone to slipping because some clutch material has to bed-in to the flywheel for the system to eliminate slippage as much as possible.
Well said.. auto or manual, it really doesn’t matter. Just so long as we can all agree that autos TOTALLY RULE!argh cmon everybody just chill. We all love our Subarus. Auto or Manual. It really comes down to a personal preference OR ... what your car comes with at the time, because not always does everybody have a choice.
Best regards,
