Kevin
- Jul 28, 2008
- 7,153
- Sydney, Oz
- MY'03
- Forester
- A/T
You could use a remote head unit - GME have them; the connection lead may not be long enough to go around the windscreen.
Thread dig because it’s relevant.
SG foz. Yet to hook up antenna and power. Both will be easy to run up the A pillar, power on driver’s side, antenna cable up the passenger’s side. Antenna mounted on front left guard with a Z bracket.
Tidy, out of the way and generally ppl wanting to thieve things don’t tend to look up. I went this way as it works mint in Ruby Scoo - but that application is much more agricultural looking.
The above unit is mounted using an angled bracket screwed into the small roof console. If this fails over time I’ll move to a bit and bolt arrangement rather than screws, but I reckon it’ll be all good!
The uhf effects the maps lights a tiny amount, not enough for us to be worried about it though.
Do you use the large sunnies pocket? I always thought about removing that plastic lid and mounting the unit there...
Not really, lots of space in that pocket, and it doesn't seal around the unit - you can see the cooling fins in that picture.Have you thought about overheating as a potential issue with the rear heat sink mostly covered?
