Dedman’s Custom 9000lbs winch and off road bumper
Few questions:
*Why did you use angle not RHS sized to fit inside the rail with bolts passing through?
I did consider this but there were a few reasons that i went for the angle instead;
1) As shown in the picture above the cross section of the rails is not constant internally meaning that cutouts would have to be made on the RHS to accomodate this which would weaken it which made me decide a more heavy angle would ultimately be stronger.
2) The approximate dimensions of the rail are 50x100mm (external dimension) which means that the RHS to sleeve that would have to be around 47x97 or something similar I size which does not exist meaning you would have to get a smaller size piece and put shims everywhere to make it fit or build your own section.
3) The internal corner radius of the rail: Im not sure if the corner radius on a RHS would be as large as the radius in the rail meaning it may have to be ground down to fit. Presumably if using RHS the wall thickness would be less than that of the thickness of the angle meaning grinding the corners would weaken it more.
4) Because of the way I designed the bar the angles do not have any real torsion induced in them (twisting about their length) meaning using open sections such and angles do not really weaken the design compared to closed sections.
5) Im not entirely sure the rails are perfectly parallel meaning that if the metal being inserted into the rails was the full width it would get stuck easily. This is also the case for taking the bar on an off. Even with my angle sections which were relatively loose fits in the rails the slightest twist and it would get jammed something shocking.
6) Its is easy to weld a nice thick single layer of metal to the nice thick winch plate than to join the more thin walled RHS and provided a strong structural load path all sides of the RHS
The main reason really was it was easily accessible/ strong and could be cut down to fit whilst still maintaining strength.
*why not use the nuts already there on the front (in the dotted area) for your attachments points? Are these welded to the front face plate so the face plate might peel off, not directly to the rail?
Yes those nuts are only attached to the face plate and the face plate its not really connected that well to the rails (especially not for a tensile load)
Also if you only attached to those nuts you are not going to provide a strong mounting point for when the winching load is not pulling directly forwards lets say its pulling up over a ledge or to the side. Think of it as comparing a fence post belted into the ground to a pole that is held upright by a big flat base that has bolts holding it to the ground. If you push sideways on the pole/post the fence post in the ground has to bend before it will fail as does something inserted into the rails (or the rail bends....) where as the pole with the flat base only has to pull out those bolts holding it down and the smaller the base the more stress in the bolts and the more easily it will fail. The bolt holes on the forester pretty close together meaning it can not provide much force that is not pulling straight forwards.
In my head all of that makes sense but to a third party it probably sounds like a load of gobbledygook :rotfl:
*Can you give a link to the winch you got?
https://www.ebay.com.au/itm/ORU-9000L...item1c2cc5ce01
Cant really make any comments on if its any good or not as I havent tested it much yet. Seems to be well build. One down side I have noticed is that it is quite difficult to pull the rope out (this may just be because it is new and all the grease is still clogging up the gears)
You're not studying mechanical engineering by any chance? lol :iconwink:
You got it. Only a few months to go.
Looks good. 2 way brake for winching up or down a hill. Genuine Dyneema rope. I like their vid although the camera work isnt the best lol. My only worry is the reliability of the remote....
Yeah being able to winch down a hill is good. Might be needed with all this rain........
The remote itself looks ok but you wouldnt want to drop it in water. I think I need to put an extension on the receiver aerial as behind the steel of my bar it doesnt seem to have great range.
It does have the wired controller as backup and I also wired up a cabin switch.
Move the remote unit, dont extend the aerial it's a waste of time. post a picture of the remote unit i've probably got everything you need to move it i can just send it to you in the mail. extending the little radio aerial will only give you a tinny bit of gain if any.
The remote range wasnt too bad, the winch worked really well when Dedmans Foz was stuck in wheel deep thick black sticky mud, like gloop :monkeydance:
PS: dont forget to unwind your rope & wash it...Dyneema doesnt like being kept dirty...the grit in the mud cuts the fibres weakening it. Already washed my extension strap, hanging up drying now :iconwink:
What is your logic behind this?
My thinking is that currently the wire is behind a large negatively earthed metal surround that is acting as shielding and it the wire was extended outside of the bumper it would receive more signal.
The winch worked really well when Dedmans Foz was stuck in wheel deep thick black sticky mud, like gloop
Yep it sure did :ebiggrin: Pity your car was not really a heavy enough anchor for the winch......
Yep Ill get on that tomorrow. Haven't had time until now.
Been thinking bout that...you could knock up an anchor for when you're out by yourself with no trees, similar to a boat sand anchor. Basically 2 flat blades at a 45' angle to a mount longer than the blades. Boat anchors have this hinged for easy storage. Definitely over-engineer this as you dont want it snapping lol
^ My folks actually have an old sand anchor floating around which I might steal for just this occasion. Im maybe thinking of going to tassie at the end of the year and doing some of the really tough west coast tracks, most of which have no trees around them and heaps of peat bogs so an anchor would be definitely required. Im curious how much anchoring force an anchor can provide though....
The idea of the angled plates is that the harder they're pulled, the deeper they dig into the sand. On a boat a heavy chain is needed to keep the angle of pull low, but that wouldnt be needed in your application.
IMO it should work well, the only query being its strength. But even multi ton boats use them in pitching seas....I guess they are simply bigger/larger blade area, also stronger
Thinking behind that is as extending the aerial is a passive gain increase, to a circuit that has little to no active gain or booster the increases you'd be looking at would probably be something like .5-1dB. Coupled with it being behind the bar which is kind of acting like a faraday cage theres alot of attenuation, electric motors also induce noise in radio signals (which normaly shouldn't be a problem unless its a cheap transmitter/reciever). You could overvolt the transistor in the sender...do both and you could control the winch from like 50-60metres away
Yeah thats how i was thinking that the bumper would be acting. What I was thinking was to extend the aerial so that the end section was not behind the faraday cage resulting in more signal received.
To be honest from my test it seems to be pretty good as it is so at the minute i probably cant be bothered changing anything.
Here is a video of the first time I tested the winch. I was trying to pull the car sideways out of a deep rut which was causing me issues. Worked flawlessly :cool:
[ame="https://www.youtube.com/watch?v=IeZ3dbqsr3Y"]Subaru Forester Off Road -- Custom Winch Bar First Test - YouTube[/ame]
The winch got you out of trouble alright :)
However there is one thing I did notice, or should I say didn't notice & that was a dampener on the winch cable/rope for the recovery :cool:
When we were in Wombat SF & his Dyneema rope snapped under high tension, I watched as it simply dropped to the ground...there was zero recoil! :biggrin:
While I agree a dampener should always be used, at least with Dyneema its not as critical.
I still have to work out how to have a dampener on a snatch strap without it simply sliding down the strap during the recovery...making it pretty useless! Any ideas?
buy one of those simple cotton bags from aussie disposals to keep your snatch gear in, tie it around the strap as a dampener helps to leave a set of gloves or something in it too for a little weight.
I've heard Dyneema can let go but never seen any break to begin with, then again i recon if the Dyneema did flick back with a shackle or snatch block (an ancor had broken or something similar) a dampener would help.
NachaLuva one of these things https://www.aussiedisposals.com.au/haversack-wh1-black
Yeah should probably get some kind of damping device. It wasn't a particularly stressful winch so I wasn't to fussed. Not sure were is the best place to put it either because even if that dyneema rope was traveling at the speed of sound it is so light that it is unlikely that it would cause serious injury. The dirty big hook on the end of it on the other hand.....
Dusting of an old topic. With in some weeks I want finally instal the winch I have on my fozzy.
I want to copy the way how you mounted the angle plate in your car. Reading the topic several times, I am still unsure where you made the holes in the rectangular-ish sections*for the Bumperbolts. I understand that you opened the front but I no clue where you drilled the holes. Please help me out!?!
Are you still satisfied with this setup?
