Dedman
- Dec 3, 2012
- 766
- Perth Western Australia
- 1999
- Forester
- 5MT
So as many of you may know my previous 4000lbs winch install failed quite badly due to a bad quality overloaded winch so I decided to upgrade to something more powerful.
The 9000lbs winch I got was far larger than the original 4k one meaning that it would not fit in the same location. The original mounting points were not really strong enough either so I decided to do a complete custom install.
I was originally hoping to get a cheap second hand SubaXtreme bull bar and mod it for a winch but after months of searching I gave up on that one….. However I still wanted something to improve approach angles and replace the plastic which was getting trashed
I was debating if I could modify a bulbar from a hilux or similar to fit instead of getting a SubaXtreme one when I just happened to stumble across about 12meters (in 3m lengths) of relatively thin walled galvanized steel tube on hard rubbish (what idiot put that on hard rubbish…) the perfect material to make a tube style bumper. I discovered that the steel I found is actually very hard to come by with most places selling much heavier tube which I took as a sign that I should definitely go ahead with this build.
After some investigation into other winch bar design I decided something like this would look good on the forester;
Went and picked up a sheet of metal and some angle from the steel place and was ready to go.
It was very interesting trying to securely attach a sheet of metal to the roof of the forester when the metal was wider and longer (6’x4’) than all of the mounting points……
I didn’t take to many photos along the way but here is what I have;
And here is the finished product. It is the best approach angle obtainable with such a large winch and I am super happy with the result.
I also took a time lapse of the whole build which isn’t a bad watch if you can watch it in relatively high quality.
[ame="https://www.youtube.com/watch?v=4-vUoHTnnOo"]Subaru Forester Custom Winch Bar Build - YouTube[/ame]
You may also notice that I have a new sumpguard/bash plate.
It is made from 1.6mm steel with reinforcing angle protecting the sump which is damn solid. Mount in 6 places with 8mm bolts and provides great protection for the exhaust headers as well which my previous guard did not.
Here is a time lapse of that build but it isn’t as great to watch but still shows how much work went into it;
[ame="https://www.youtube.com/watch?v=nGkUg6bmKP0"]Subaru Forester Custom Sump Guard Build - YouTube[/ame]
Super happy with how the forester is looking now =) Can’t wait to try it out!!!
