Measuring up for the storage system, going to build a fridge slide into the floor.
To anyone installing a trailer wiring plug, or reverse light, on the SF5 this is where the factory plug is located for a wiring harness
And the beginnings of my switch panel (plywood plastidiped), for 2 12vlt outlets and a 50amp anderson plug. I've also got a 20ah sla that can go behind the panel, but i doubt i'll install that as when i get a fridge i'll be putting in a dual battery system under the hood. We only use the 20AH for charging mobile phones and running lights when camping.
The fused control box for the wiring panel is going to be waterproofed as well with a 100amp isolator switch and push button battery gauge as it'll be directly to the starter bat for now.
PART 2!
Well i've given up for today. Found a spot to drill out and put a captive nut for the cargo barrier's top point, and I'll make some new bottom brackets to fit to the tie downs. Still might make some arms to the child restraints not sure, does mean no drilling into the body work.
All my mates were out drinking piss without me so here's my friend i call him tie down strap.
My clock doesn't work? how to fix it.
Pull clock apart, locate the 510 diode/ remove -> clean it up -> re solder it. (i HATE working on surface mounted components)
Trick if you suck at soldering surface mounted components like me, with a HOT iron (350ish is good), first hold down the component with a sharp pencil. Then heat the joint that's cracked, as soon as the solder is molten while still pressing on the component with your pencil remove the iron. wait a couple seconds and take the pencil off. Mine moved down a touch when i was reattaching it that's not a problem here as the tracks on the board aren't very close together most other boards that would have put the diode between two tracks.
