Ok, worked on fitting the two worklights last night, couldn't do the lightbar as we didn't have a relay handy. It took quite awhile but worth it in the end I think. I bought some switches from Super Cheap, 2 x $8 and 1 x $5. Mates work supplied all the tools + bits/wiring for free so we got to it.
Installed the rear LED light first in the boot along with a switch which is nicely tucked away but easy to reach. Had to take off all plastic panels to run the wiring to it but the hardest part was getting the wires through the hole from the boot door to inside the back brake light cavity where the wires were spliced into the wires which feed the original boot light.
Next was the Cree LED worklight which is super bright! Drilled a hole in the ROLA roof bar, then stuck the bolt through and stuck the nut on the end. Then ran the wiring down the boot sill, underneath the brake light cover and into the cavity where all the wires are. Cut out a rectangle for the switch to sit in the carpet interior - probably the hardest part to do. Took awhile to figure out where to put the switch but in the end it was worth it. After cutting a rough hole, had to file away at it, until the switch sat nice and tight. Then it was simply a matter of doing the wiring. One problem we had was mounting the light on the bar. The bolt wasn't long enough so we had to take off the bits which allowed you to rotate the light to get that extra length. Just means I can't adjust the light much.
Decided to put the lightbar up on the front ROLA bar. Tested it out one night, and there's no glare at all on the bonnet and the light seems more spread out from the drivers seat than if it's mounted on the nudge bar. That leaves room for a pair of spotties then!
Hopefully do the lightbar next week.
Will put some pictures up today/tonight.
