scooby
I picked up and Engo 9000s w/ synthetic rope only weighs 60lbs
s
I'm using a harborfreight universal winch plate to mount.
Now the bigger winch is going to draw more amps..
My solution is an Optima D35 yellow top inconjuction with a Tribeca 3.6l H6 130amp alternator..
I had good results with an ej22 fitted with an h6 3.0L 100amp alt. on my hatchie..just on extra rib on the pulley .
Now I'll have to get a snorkel as the airbox under the front bumper has to go...
Let the fab begin..
Two 3/16" plates bolted to the bumper mounts as a start.
The lower tie bar with 2" box tubing welded to the tie down mounts.
I welded mount tabs for the skidplate as well.
The lower tie bar will be integrated into the bumper mounts vertically for four points. This will distribute the pulling force across as well as support the bumper/winch..
The grille will have to get a trim . This will allow for proper setback of the winch . In effect no loss of approach angle.
s
Let the fab begin..
