Winch on Forester
Dedman
Perth Western Australia
5MT
Hi All. I recently put a winch on my forester so though I would write something to show what I have done.
I had been toying around with the idea of putting a winch on the Forester for quite some time. As my forester does not have airbags to deal with I thought it should be fairly simple task. Upon removing the front bumper it appeared that there were sufficient mounting points to support a relatively small winch however they were not near as good as the mounting points in the older Subarus. It was also evident that there was a possibility for mounting the winch neatly and completely inside the bumper with the hook of the winch coming out in one of the gaps in the nudge bar.
Being a poor uni student and all I decided to have a look on eBay for a winch. There was heaps of choice available and all very cheap although the quality may be questionable. I settled on a 4000lbs winch with synthetic rope for $160 delivered to my door as it sounded like a good deal and didn’t blow the project budget.
https://www.ebay.com.au/itm/150615736714?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Two days later this is what I received
This winch was made for the location I had in mind fitting perfectly.
After investigating how the winch would fit exactly I next began the task of designing the supporting bar. I did many hand calculations and also conducted a Finite Element Analysis on the bar to check that it would be structurally sound. The results looked very promising and showed no issues with winching force.
I was stuck for a few more days without a workshop so I decided to get the electrical works done whilst I was waiting.
I disassembled the housing for the control switch for the winch and mounted it next to the cruise control switch which was nice and neat and well out of the way of accidental knocks.
The next decision was where to mount the control solenoid. I found a small otherwise unusable space between the headlight and the battery which worked perfectly and also was positioned such that I could significantly shorten the power leads to the winch. I had concerns that the wireless control might not work well in this position but so far I have not experienced any issues. Also all of the control units are completely sealed so there shouldn’t be any issues with mounting them down so low for water crossing.
Next stage was making a suitable bar to be able to support the winch. I decided that a span of 75x50x5mm angle should sufficiently take the load and two pieces welded together would fit the winch nicely between them. I sourced 2 metres of 75x50x5mm angle and 2 meters of 40x40x5mm angle for $40 and also picked up some longer high tensile bolts for $10 to mount the winch as I would be mounting through 5mm of extra steel
Here is the design I came up with, similar to the one tested using FEA the only difference being in fabrication variation.
The most difficult part was creating a sufficiently strong mounting point to the body. My original design had a lot less steel in it but after some calculations and testing it was evident that excessive deflection was an issue. The biggest issue was the low torsional stiffness of the angle which I solved by boxing it up with a second piece of angle. Although being heavier that I was hoping (winch and bar weighing 20ish kg) the end result was a very strong bar.
Cleaned up the bar and gave it a coat of paint. Mounted the winch, shortened the power cables and bolted it all together. The next stage was doing the finishing touches to make the front of the car presentable again. Firstly the bar I had made meant that the plastic internal bumper could not fit. As this is the mounting point for the nudge bar this was an issue. I decided that the easiest fix was to just cut down the plastic internal bumper to make it fit around the winch. This was a simple task and worked very well.
Next I had to modify the external bumper for the winch. As the winch was completely inside the bumper I had to create an access hole so the free spool could be engaged and disengaged easily. A large diameter drill, a knife and a blow torch to smooth the edges made an easy job of this. I also had to create a cover for the access port. I made this from the plastic from an old oil drum which matched the bumper. A piece of foam melted on to the other side of the plastic created a simple tight fitting cover.
Last part was cut a hole in the front of the bumper to allow the winch rope through and mount the fairlead.
Once I had bolted everything back together again the last problem was to determine what to do with the number plate. I decided the simplest thing to do would be to hinge the number plate so that it could be lifted up out of the way when winching. Not sure how legal this is but it was a very neat solution to the problem. I deliberately fixed the hinges with slight stress between them so the pivot was stiff and the number plate would stay up when folded out of the way.
So here is the finished product. I haven’t had a chance to try it out on a track yet but my initial test proved that the winch could drag the car on flat ground with all four wheel locked which should be sufficient to get me out of most situations. With this load the winch didn’t struggle very much and there was no evidence deflection in the bar so I’m happy. Total cost was around $250 for winch, all materials and all consumables. Around 2.5 solid days work and many many beers :ebiggrin: :ebiggrin:
Hopefully I will have some good pics of the winch in action to post soon!
Here is also a video version of this writeup with some winching footage;
[ame="https://www.youtube.com/watch?v=wXgw2GzS0s4"]Subaru Forester Winch Build - YouTube[/ame]
Sweet but you better invest in a snatch block, 4k winch is not a lot and thats on the first wound of roap/wire. I have a 9k on my jeep cherokee and i have stalled it before and i now use a snatch block it doubles the pulling power.
my next project...ENGo 9500lb winch on foz...
I 'm picking up an Engo 9000lb winch and fabbing a real offroad bumper..!
It will go on my '98 foz.
https://www.metaltech4x4.com/p-487-engo-winch-model-e9000s.aspx
The plastic goes in the trash...worthless anyway..
I was kinda shocked to see no bumper reinforcement x-bar made from steel...Unlike my '03 outback which is steel...
Plastic is just just crazy for a x-bar...!
Yes my '98 has airbags and it's legal to mount a bumper on...
I had no problems with my '03 outback w/ steel bumper...it's still airbag compatible..
Given the winch is fairly light with synthetic rope ...about 64lbs vs steel cable around 96lbs roughly.
Next will be a 4" lift to help with bumper sag..:twisted:
Yes, well done DW! And Welcome Aboard!
G'day DedmanWalking & :welcome: to ORS.
Awesome job on the winch, very well done :discomonkey:
I had previously disregarded the winch idea.... Now.... I want one of those!
Great work, I love it.
Jacko.
Thanks for all the positive feedback.
The winch did come with a snatch block (although a pretty ****ty one) but so far it has not been necessary
Took the foz out to the Bunyip State Park today which was great fun. According to the parks website the double black diamond rated tracks I went on are only suitable for modified 4wds and drivers with extensive driver experience and advanced training. All I can say is misleading advertising! Forester did them easily only getting stuck once when I tried a stupid line hoping to get stuck to test out the winch.
The winch performed flawlessly, dragging the car for a couple of metres with most of the weight of the vehicle being supported by the sump guard and body work. Winch did this on the second or third layer of the drum and did not even strain that much so no need for a snatch block yet.
Only issue I had was that I should have attached the cover to the access port in the bumper because in my excitement to try out the winch I have lost it somewhere.
Very happy with this mod, gives me complete confidence to go out on my own knowing I will return on time!
https://flic.kr/p/f1YZnL
f1YZnL
looks great mate, probably the best winch set-up ive seen on a suby and i can imagine it will inspire some more creations in the near future for other owners :iconwink:
any other mods to your car? or plans for any?
Which tracks did you do? I love Bunyip...some great tracks! Shame Gentle Annie Tr has been graded now though :(
Lol :rotfl:
PS: Do you have a LSD in your SF Foz? I've found the open diffs to be very limiting on what I can achieve...
Tracks i did;
Little Bunyip - Probably the most difficult
Andersons Track - greasy as all hell almost as hard as Littly Bunyip
Bunyip Ridge track - way to easy
Western Tk - Easy except for one greasy section
Gentle Annie - easy
Tea Tree Track - Easy
I have fully open diffs front and rear which sucks but but amazingly didnt really have any issues provided a good line was picked. Also was running standard road tired at full pressure.... The ability of the forester never ceases to amaze me...
As for mods;
Have a 50mm strutt lift
UHF radio
Inverter built into dash
Future mods;
Sway bar disconnects
Try engineer some diff locks front and rear (probably dreaming with this one and currently well out of my budget but maybe some time in the future)
Better off road tires
Maybe a snorkel
haha this is awsome we could of used this when you got stuck in the bog hole last month! or when i fell in the rut
Great install, I'd never guessed that a winch could have been tucked in so nicely. Now I want one!
That trail looks awesome, got more pics?
Wow! That is by far the cleanest winch install I've ever seen on a Forester. Kudos!
Tracks i did;
Gentle Annie - easy
Gentle Annie is gentle again after being graded, sounds like Tea Tree Tr has been too, it was massively rutted last year. A worked Patrol with muddies turned back as his locker wasnt working!
I'll have to try Little Bunyip & Andersons Trs. Make sure you have a go at Phasmid Tr...if there's the slightest hint of rain you'll have fun lol. Hint: use plenty of momentum :iconwink:
Warning: Dont attempt Phasmid Tr downhill...we did...bad idea! :rotfl:
