BeeJ
Guys, been doing a lot of reading on this site and think this would be good to add here/clear up. Please correct me if I have this wrong.
Seems generally accepted that 2" on struts only is max lift before angles on cvs and other drive components are compromised. Heres the part I want clarified.
If body lift lifts chassis & struts keeping drive components at same height relative to ground but body higher surely a combination of struts and body lift together would give you an even higher max approach and departure angles and gained ground clearance without drive issues?
eg: lift struts by more than 2" and offset that extra lift buy using different body only lift to in affect lower the components back to a 2" strut only type lift.
If 2" body & strut combo from someone like sumo gives you the same under diff/engine clearance as factory but better approach/departure, can you install this kit but use alternative strut lift which is higher?
hope that makes sense
Looking for clear answer on what maximum lift is before drive issues, what order and what components are used
maybe something like
1) 4" Strut lift
2) 2" body
result on drive angles = equivalent 2" strut only lift?
Just saw earlier in the thread SG foresters can't have body lift due to revised front end?
1) 4" Strut lift
2) 2" body
