nipper
Was that going through a repeater station?
What frequency are you using?
Kevin,
Mounting the antenna on the hood hinge sounds like it would be neat.
When you had the antenna attached to the hinges of the hood could you open the hood without fouling the antenna? Also when driving at speed did the antenna bend back and bash against the car?
Got any pics of how you did that?
Thanks
Ok, that explains it. HF is much better in this regard. HF is rarely used here now- with UHF you get better signal quality but lose out on distance, which is why they have repeater stations. We don't have repeater stations here for HF, just UHF. You also can't realistically tune the aerial with UHF as you can with HF.
Hmmm...so if an aerial is gonna cost me $50+ & I can get a new Uniden 80ch + aerial kit for ~$200, maybe I should hold off & do that?
Have been reading high gain antennas are better for flat highways & low gain better for hilly country...is this true? I really only want it for when I'm offroad, ie, around bends, over hills and thru trees. Or is this asking too much lol
Yes I'll agree, when it comes to UHF.UHF is line of sight, and is quite poor in hilly terrain. I understand low gain aerials can help, but it still won't be as good as HF.
As I said in an earlier post, I have a 6" whip aerial, which is 6dB.Instead of trying to explain the difference between a 3dB, 6dB & 9dB antenna I'll let the following pics do it instead.
