stilson
This is what I've been thinking (check my ultimate ORS thread). The dual range moves all the ratios closer together though.
I'm sure there's a happy medium.
i didnt think you could run the dual range in the turbo's???
You can run them, it's just a matter of durability with the extra power of the Turbo.
They definitely can hook up to a turbo. Just be nice to it. Dumping the clutch is a big no no
I've often thought it'd be cool to just have 6 gears, gear 1 would be something so low you could skip all together on the road.
Don't abuse it - "dry clutching" is out of the questions, as it should be for any subaru gearbox!
Please explain???![]()
Maybe, it depends on the 1st gear ratio. Venom got away with a version 6 (?) STi gearbox with 4.44 diff ratio offroad for a while with the H6 in front of it. But steep hill climb that a 2L DR foz and L series DR would do with a little bit of work was tough going on the single range H6...
Go the dual range, go gentle on it and you'll love it and it'll look after you too.
It's kind of a moot point for us North Americans, it'd be a ton of money to either go to a dual range gear box or get some custom gearing.
Given the current gearing of my forester, I think one gear smaller would work. 1st is just a bit too fast, I think a gear lower would make slow speed maneuvers a lot easier.
This is basically what the low range does - in the L series (1.59:1) low 2nd is just shorter than high 1st and so on...
I may be wrong but in my SF Foz, it feels like the gearing goes 1st low; 1st high; 2nd L; 2nd H; etc. The better low range of the L-series will make a difference![]()
i agree with the 1st low then 1st high then 2nd etc
Easiest way to find out is to do 2000RPM in each gear and record your speed.
I have done this and that's how I worked it out. Can't remember what it was though.. will have to check it out tomorrow. I think I was doing about 4000rpm.
