taza
Thank you for the precise answer, how simple is swapping from SF struts to SG?
If you don't know how to swap suspension then you best not do it yourself without help. Personally I'd say it's easy and you could do the rears (don't need to do the front), put in heavy duty springs and 1" or 2" or higher lift blocks while your at it in a few hours with the right tools.
I have 225/70R15 and they rub with SF struts. I have 70mm blocks with raised springs in the back of my 2001 Forester too
Be aware that going quite a few sizes larger in tyres will affect your performance and fuel economy.. It can make a huge difference, added weight and the size means the motor has to work harder to get upto speed and too maintain speed. I reckon it has take over 1/3 of my performance or more away from my Foz. This is comparing stock size road tyres on suabru alloys rims to heavy big offroad tyres on steel rims...
It is just something to consider, but the bigger tyres do go much better offroad :iconwink:
