^ dont worriy about that untill you get caught :iconwink:
I'm not sure about how it works where you are Ratbag, but in NSW, that size won't be legal
I know in NSW that you are allowed a +/- 15mm (I think thats right) on what's OEM.
Might be worth checking that out too mate :iconwink:
It's just been changed Australia wide, mate. Thanks for your concern.
This document is somewhat more legally sound IMNSHO:
https://www.vicroads.vic.gov.au/NR/...mber8Guidetomodificationsformotorvehicles.pdf
Please correct me if I'm wrong, but this allows me to run 215/70 16" as less than 25.4 mm increase in tyre diameter.
I had a look at the link & if I'm reading it correctly, it's 25mm (25.4mm) for width .... not diameter.
If you look at 13.3.2 Option 2 (No 2 -1 & -2) the +/- the 15mm still applies if I'm not mistaken.
But as I said, I could be reading it wrong
But as you say, it's the insurance part of it that really matters.
I think that the following document may be the definitive source for VSB 14 LS parameters:
https://www.infrastructure.gov.au/r...Tyres_Suspension_Steering_V2_1Jan_2011 v3.pdf
Yes, it's tricky indeed.
I'm that tired at the moment to even try reading & understanding that link tonight. Once I've had some sleep, I'll be able read it in more depth
Probably a fair rule as the same factors effecting your motors ability to accelerate your car with larger tyres also effect the brakes ability to decelerate it.
Pretty conflicting information to that on the coopers website.
Yes, right you are again, RB.
I Don't see why they would allow heavier, higher c o g vehicles to increase tyre size and not us.
Shame on me for expecting logic from a government department.
I have said once before here that Roo2 is the most 'balanced' vehicle I have ever driven, out of all the really flash stuff I have managed to talk myself into the driver's seat of. Someone must have noticed that I have a bit of a talent at this ....
THIS is perhaps the reason why that 'balance' must not be interfered with ... Not by fitting larger tyres; not by changing the suspension; not by almost anything.
THIS is the price we pay for having such superbly designed vehicles (for what they are ... ). They don't "appreciate" any sort of modifications. It upsets the 'balance'.
I thought in WA we had different laws to those about tyres??
Gidday Taza (aka "HB" ... :lol![]()
The document I found is for all of Australia (Federal law).
Except maybe in NSW where the rules are tighter, apparently.
Seems it is OK for the States to have tighter rules, just not looser ...
However, I don't claim to be an authority on this; let alone the ultimate authority ...
HB??
Ok I will have a read over it when I finish my uni assignment, if I make it off this website first![]()
That last sentence is probably the most important, going as it does to safety and intended use.I'm about at the same stage as you taza with mine
Mine currently have about 36k on them & I'd say they are about 66% (33% or 18k-20k left) Thus giving me 54k-55k out of them
I should & might even be able to squeeze a little more out of them too if I'm lucky :iconwink:
As for noise, I don't find them to be loud at all. If anything, they are quieter than I thought they'd be.
However, if you corner hard, they do growl a little, but nothing major
Yes I'll most definitely 2nd that :biggrin:
They're brilliant offroad, fantastic in the wet & great in the dry![]()
Gidday Taza
Lookie here:
https://www.offroadsubarus.com/showpost.php?p=39501&postcount=12
:iconwink: :rotfl:
Yeah mate. You are going to have to ditch a LOT of stuff if you want to do well in your Uni course.
Trust me.
You have to make Uni your first, second and third priority.
I am managing so far but this site is very addicting. I am finding myself spending abuit less time on here though![]()
i already have a set of my old rims with the bridgestone dueler HT that i was going to use for on the road and everyday tires. i was hoping that a less superior tire would be cheaper then the yokohama's possible the bridgestone dueler AT because from what i understand they are inferior compared to the yokohama's
On a completely dry surface, a completely bald tyre will give the best handling and braking, assuming that the casing is not compromised.
