stilson
Hi guys, I'm looking at installing around 2" of lift and was considering 1" subtle strut top blocks and kings or dobinsons.
After seeing the positive camber on a 2" lifted SF and the uneven tyre wear I think I might need to give the subtle blocks a miss and get some with camber correction.
Question time:
What are my options for camber correction?
How do I know if I have SLS in the back?
Can I get custom heavy duty springs with 2" of lift and not use blocks at all?
(still have to overcome camber issues obviously) - the answer is no unless you want to lift a wheel off the ground as spring will all but exceed strut travel.
Cheers,
Seanan.
Question time:
Cheers,
Seanan.
