Subaru AWD vs The Rest
dirtyRU
Loveland, CO
I saw this vid once and have looked everywhere for it in the past year & finally came across it again. That Nissan Rogue has the CVT - that's the main reason i've been against those types of trannys from the beginning.
[ame="https://www.youtube.com/watch?v=0_MXK2nzt2Y&feature=related"]https://www.youtube.com/watch?v=0_MXK2nzt2Y&feature=related[/ame]
To be fair to CVTs, a lot of that likely comes down to transmission programming - these are all vehicles running electronically-controlled gearboxes, and if it ends up in a situation that the software doesn't know how to cope with that'll throw the 'box for a loop. And when the AWD systems are also electronically-controlled and tied in one way or another to the transmission and wheel speed sensors... You can see where this is going.
As an example: there's a spot (uphill, slightly off-camber, washboard surface with gravel/scree over it) on a local trail that the 5EAT in the 2007 H6 OBW we have in the family completely freaks out on. It basically turns into a one-wheel-drive vehicle in a spot I've taken FWD hatchbacks through with no issue. FWIW, disabling traction control (which also kicks out VDC) solves the problem, but that's a traditionally-geared electronically-shifted automatic.
One thing (and about one thing only) I'll say in favour of the Freedom Drive II Jeep Patriot is that the CVT works well and is capable of altering its shifting to simulate a traditional low range. I really wish that Subaru would do something like this with the CVTs they're now using, because God knows these vehicles could use it.
Or just get a manual transmission and get where you want to go. The Nissan X-trail that was with us at Wee Jasper proved to me that the marketing department designs hopeless cars
Awesome vid... go Subie! :monkeydance:
Thats the problem now, cars are designed to look good first, go well second.
The marketing dept should have nothing to do with design!!! :furious:
You're not wrong there :yell:
If only car manufactures listened to the public (their potential buyers) as to what they thought & said a little more, then their vehicles & sales would definitely be better ;) :)
Gidday Folks
Not wishing to rain on anyone's parade, but ...
To be even fairer, am I the only one who noticed that the two Subie tests were the only ones that didn't have rain drops showing on the front element or filter of the camera lens?
That having been said, I don't think that Roo2 would have any trouble with that at all in the dry; and in the wet it would very much depend on what the surface was, and my tyres.
I also suspect that the almost nominal AWD of the Subie automatics (90%/10% F/R) would not work very well there either. It is my understanding that the manual gearboxes from my model Impreza on (1993) have a power distribution that varies between 60%/40% and 40%/60% F/R. AFAIK, none of the manuals fall outside of this range. However, I am more than happy to be corrected if wrong ... :iconwink: :poke:.
These things are far more complex than just gear ratios, IMHO.
I think you're right re the manual gearboxes Ratbag :iconwink:
From what I've been let believe, the manual in my MY05 Forry is a constant 50/50 split all the time.
But please correct me if I'm wrong :)
Gidday Mr T
I don't know, but I doubt that.
Even Roo1 had the computer-controlled, viscous LSD in the middle that varied the output to front & rear within those limits depending on some arcane magic that I don't profess to understand.
[ame="https://www.youtube.com/watch?v=Q7dVFY5CxT0"]Subaru AWD vs. Everyone Else - YouTube[/ame]
It tries to be - with all four wheels rotating at the same speed in a straight line you're 50/50. If you launch it from a stand still with a wet road the power will try to go to the front wheels as they're the ones with the least amount of traction which is the reason why Subaru have incorporated an LSD in the centre diff.
This LSD is what changes the power split front to rear when one axle (front or rear) loses traction. It can be constantly changing as you drive but in a straight line with all tyres the same brand/model/wear/psi you'll have a 50/50 split. The LSD only works once it starts to bind - on a stock 2L foz it's not often that the LSD will be doing any work if at all. Where as a 2.5L turbo foz it'll be a different story on a wet road, full ball from stand still. They'll probably also have a higher rated LSD in the centre.
[ame="https://www.youtube.com/watch?v=zlL0AybxBlE"]Symmetrical All-Wheel Drive Traction Test - YouTube[/ame]
Last weekend we went to some offloading.
Friend of mine was in Hyundai Santa Fe.
I don't know what and how Subaru made his AWD, but it is working better than Hyundai for sure.
In one point we turned to the trail with some good challenges my Forester was ready just go go and go But Santa Fe stock on first simple obstacle with uphill part
I saw how Subaru wheels spin and Hyundai and literally you can see that Subaru AWD trying to use all all wheels if any of wheel spinning , while Hyundai even with locked central differential was just keep spinning.
The Subaru AWD system really does work very well, even in standard form. Add a few mods like some lift, better tyres & LSDs & its a winner!!! :lildevil::monkeydance:
My Subie has front and rear skid plates and lift kit...
Tires is the best possible upgrade to this car and its coming to be next upgrade
But I didn't know that LSD can be added....please more info
This issue has been the subject of much discussion this year. Some of us have gone into some detail as to what we have done in this area. I have gone into some detail in the build section of the forum on my own car- you may want to look there. I think diffs utterly transform the car- more so than tyres
