eddie351gt
Im new here, I purchased a 2000 model outback yesterday, it seems to be a decent car, i've been reading up about the problems associated with the EJ25 engine, and i have a few questions,
if i wanted to do replace the headgaskets :
a) can i do it with the engine still installed
b) replace the headgasket with somethign from a newer model which doesnt suffer the same fate of blowing head gaskets (ie, a better quality headgasket)
also, if i decided to get this done by a workshop, what would i expect to pay for this work (normal mechanic and subaru dealer prices if possible pls)
i picked up the outback for just under $4000, so i knew that i would need to spend some money on it. It drives fine, doesnt blow any smoke,
- there is a steering wobble when braking from 100km/h (but no wobble when braking under 60km/h
- temperature sits between 1/3 to 1/2, but with the aircon on, i have seen it creep up to 2/3 to 3/4, once i turned the air con off, the temp crept back down again (also the drivers side thermo fan i've noticed hasnt started up when warm, the passenger side front thermo works fine.
the engine bay is spotless, there radiator fluid is spotless and the oil is normal and not emulsified, so im not sure if i have a blown head gasket or if it is a buggered thermostat.
also, any ideas how to get ciggarette smell out of the aircon? i've tried cleaning the pre-filter behind the glove box, and also spraying it with frebreeze, but i can still smell it (being an ex smoker, it is pretty obvious)
I appreciate any help you may give me in advance
thanks
Eddie
thanks
Eddie
