Well, pretty much 5 years in the planning, one unit built about 4 years ago for Engineers testing and some pretty shoddy drawings saw this project parked till technology could catch up.
Now, what with plasma and laser cutters that can extrude up to 2 inch thick steel plate and software that can create all your sheets metal templates and export the design, cut and bend all to near mm precision has now seen this project reborn from the ashes.
Project Rear Bar is back on the drawing board and in CAD design phase.
Here is a sample of the partial design concept:
This is the stress analysis with results at point of material fatigue and failure. Pretty impressive stuff.
I've come up with my own rear recovery system that allows for D-shackles to be attached on either side of the rear bar. I've designed it such that they are located in the same alignment as the point of contact with the chassis. If need be, you can also have a D-shackle hitch.
For now, this is where I'm at. A massive way to go, but being able now to do the design and design analysis/testing in my own time rather than having a model built and physically testing is a major saving.
So now all I need to do is finalise the design of the sheet metal for the external panelling, design the wheel carrier arms, design the tail light locations and carrier arm couplings and then I can go into production
Oh and also upgrade the wiring to the garage to take the welding kit
