TrooperBrian
- Jan 30, 2011
- 26
Hey everyone, just found this forum from the guys over at SubaruForester.org, thought I would share my rig these days.
The front bar details:
Full Thickness 5/16" Hotroll Plate
2.5" OD Main Bar
2" OD Top Bar
Grade 8 Steel Bolts, all mounting points.
Grade 5 Steel Nylon Locknuts, all bolt points.
Twin 130w Offroad Lamps w/ 30A Relay, wired to Siren Controller
Full bends and fab by hand, no heavy equipment or oxy-acetylene fuel rosebud torch. (why it took so long)
Oh and thanks to the guys at TSP for always getting me the right parts, and the guys over at Pacific Steel for getting me good deals!
Eventually I added parts to the rear bar including a hitch assembly and some tiedown loops.
Also a 2" lift all around.
Starting with 4" Sch10 pipe, runs about 4.3"ID, which is the perfect size for the front strut cap.
A bit of math:
Removing 1.57" from the circumference of the pipe gives an overall reduction in pipe radius of about .25", and a reduction of .5" to about 3.7"ID, which is the right size for the rear struts.
Just cut out the notch, weld it back together, then true the radius.
The front was about as hard as the rear. But the bushing bolts could be directly pressed out.
Here's the strut out.
How I designed my lift:
For an extended strut bushing, I used 30mm M8x1.25 A2 Stainless bolts, with G8 nuts.
The rear was a bit harder. For one it was hard to place jackstands where the car wouldn't tip over with excessive prying force. The rear sway bar also had to come off (like a tutorial I read) in order to facilitate enough clearance to get it back in.
Here is the rear spacers done:
Here is the front lifts in, compared to a stock height in the back.
And here is the rear done with the tire on the ground.
On top of that, the brake lines had to be disconnected front and rear, and the ABS sensor on the front wheels. Then the brakes bled and reinstalled.
I just found this picture from a few years ago, I don't think I ever posted it.
2.5" OD Main Bar
2" OD Top Bar
A bit of math:
