TrooperBrian
- Jan 30, 2011
- 26
Had some time to get back to work, so I've added a few things.
Two recovery points and a sump guard.
I tried what another member did using his plans and measurements:
I don't have a brake in house, and the bends failed miserably.
Instead I headed to the yard and picked up some 3/16" plate, I suspect I would bend the frame before anything gets through this thing.
Completed after fitting:
As for the recovery points, started here:
Then fitted, welded, and painted all the pieces:
Clearance of the sump guard to the sump and filter:
And everything installed:
