Stage 2 - The HID Ballast connections
Okay. Onwards we go. Kids in bed by 19:30, watch a little of Master Chef, put down a tea and it was off to the garage.
With the 9006 male connections delivered in under a week, I was now able to undertake another of the stages for the retrofit conversion.
In principal, the focus of this stage was to remove the OEM Ballast Plug that would have connected the headlight loom and add in the new plug that connects to the HID Harness Relay connection.
This picture shows you the ballast sitting on the bottom of the headlight assembly and also the plug and wiring leading away from it. This is what requires retrofitting.
This picture shows the two components that are going to be spliced together.
With the required length of overall wiring determined I removed the leads from the 9006 male plug to facilitate and easier installation of heat shrink. With the wires all soldered up, I was half way.
I reused the original black plastic sheath and used some heat shrink to cap off each end and replaced the leads into the 9006 connector. This is an example of before and after side by side.
Onto the second one and a few cable ties and the job was done.
I was going to silicone up the back ends of the 9006 plug but I could not find my small syringe, so a trip to the Chemist is needed tomorrow.
Stage 3 will be installing the HID Relay Harness. I'm almost half way through.
