spinners
Moderator
Alright, I know I have been very much on the quite side for many months now. Alas, the pleasures of a new job and the responsibilities of running a company have severely drawn my time away from the things I love.
For now, a reprieve
I really like the look of HID light. I had contemplated buying something off eBay but was put off with the legalities of it all. Yeah I know, says the man with 70 series tyres on. This way, the headlight assembly is OEM, the globes are OEM and the only things that are different are the way I am going to interface with the original OEM globe plug.
Now the fun begins. After a little plug and play trial and taking some voltage, amperage and resistance measurements, I quickly discovered that the 35w STi HID system was not going to work too well with the 55w output from the my MY05 H4 headlight plugs.
What I was going to need was a 35w HID headlight relay setup. Enter the guys at The Retrofit Source. They had a relay wiring harness specifically for an H4/35w HID system and at US$30, it was far cheaper than that available at Bright Light Automotive.
The beauty of the relay harness is that it will allow me full Low/High/Flash functionality and send the right signals to the Ballasts.
Here are a selection of the photos of the headlights.
Here is the 35w HID Harness
The Harness Relay
And the H4 interface to the OEM plug.
Stage 1 - The High/Low Deflector Solenoid connections
I tried sourcing OEM plugs and connectors but they were only available on harnesses and at $170 for each harness I decided to use the old fashion soldering iron and my own plugs and connectors.
A little bit of heat shrink really makes for a neat and water resistant job. I have not shown it in this pictures, but at either end of the heat shrink and before I shrunk it, I used some a syringe to inject a silicone bead. This would ensure a nice waterproof plug and seal it all up.
I used some corrugated split sleeve tubing to cover my handy work and used some more heat shrink and cable ties for a nice pretty and durable finish. Here is my handy work.
Stay tuned for my next installment when I undertake the same sort of thing for the Ballast connections. I think that this project will take a few months, so in the mean time, I am happy to answer any questions that you may have along the way.
Also, if you have any recommendations on how something may be done better, I am all ears.
For now, a reprieve
The Harness Relay
