Kevin
- Jul 28, 2008
- 7,151
- Sydney, Oz
- MY'03
- Forester
- A/T
(Also posted on sf.org)
Am I on the right track here? - MY03 XS auto
Possibly front diff problem; suspect its binding and overheating. "Something" is whining.
The car seems to have lost some power and the engine seems fine (leak-down test performed 3rd Dec and is OK). I notice I have to use more throttle to make it perform; especially up twisty hilly roads (Bells Line of Road) and on steep off-road climbs for example. I'm pretty sure it's using more fuel.
When I changed the front diff oil it looked more like engine oil i.e. smelly and dark not nice and clear like the rear diff.
I suspect heat is being transferred to the inner CV joints - there is evidence of CV grease oozing.
After the Simpson Desert crossing mid-year there was evidence of oil escaping from the filler / dip stick hole. On closer inspection I'm sure I spotted tiny flecks of metal stuck to the side of the diff housing - although I didn't notice any when changing the oil. I changed the dip stick O ring just in case and there has not been an overflow since.
The steering feels heavier - I initially thought this may have been due to the strut mods performed a few months ago - but perhaps not.
Tyre wear seems normal. I have not yet tried some tight circles in a flat car park to see what happens.
Also, assuming the diff has to come out what should be done to the rear of the engine while its accessible, i.e. rear output shaft seal - anything else?
Thanks
Thanks
