Couldn't have said it better myself.
Warranty? What waranty?
So the alloy would be more prone to cracking but offer better protection because it is thicker? and the other could be belted back into shape but not as robust?
Mate if you should crack the SubX guard than you're in a whole lot of hurt. They are designed to withstand huge impacts without major deflection, cracking is a result of exceeding design loads or plan negligence either way the crack will most likely be the last thing you will notice after you remove the airbag from your nose
rod
I think you nailed it Tubeofglue, well saidWe can't compare these two dissimilar sump guards as the only commonality is, that they are made of an alloy and they are better than the plastic factory ones.
* one is a designed and engineered alloy casting made to an industry standard, with a warranty.
* one is fabricated from welded sheet of unknown alloy and temper with an unknown warranty.
Whether they are made of butter or titanium they both do a respectable job of protecting the sump, how long either will last is up to how you treat them.
i dont care what anyone says, 2mm cast or 2mm rolled is NOT enough protection for the kind of driving we do. it sure is better than OEM plastic and might be ok for sand but the knocks i've copped it wouldn't of handled. so your saving $100, whooppee! is $100 worth your peace of mind? is it worth a pre tested and proved product? the only advantage it has is that it can be beaten backish into place, but can your sump and can your exhust? NO! i would rather pay an extra $200+ and get at least 5mm thick. it maybe heavier but no one will notice.
Thanks tubeofglue. Your answer to my questions is what i was after and as i have a fair idea of the Subaxtreme product i am now in a positon to COMPARE the two and make up my mind which one i will buy.
All going well i hope to be going to places i have never heard of so as best i can i want to avoid potential trouble. Thanks for the help.![]()
