FOR SALE: WV: 2002 Forester Part Out
LiftedWRX
WV
2002 Subaru Forester 5 Speed 211k
Located in Fairmont WV
Located in Fairmont WV or shipping isn't a problem just message me for a quote. If you want pictures of a certain part or interested in something not listed just ask.
*Coilovers & wheels are not for sale*
Engine, Drivetrain, Suspension & Brakes
• EJ22 Longblock $400
• EJ22 Intake Manifold $100
• EJ22 Throttle Body $60
• EJ22 Engine Harness $50
• 04 RS SOHC Complete Heads $200
• 5 Speed Transmission $300
• Lightweight Flywheel $60
• 6 puck with pressure plate $60
• Intake Manifold $100
• Throttle Body $60
• Engine Harness $50
• OEM Header $60
• Straight Pipe Cat Back Exhaust w/Resonator $150
• Rear Differential $75
• Rear Differential Carrier 'T' Subframe $50
• Engine Crossmember $50
• Rear Crossmember $50
• Transmission subframe $25
• Transmission mount $20
• Axles $50 each
• Control Arms $25 each
• Sway bars $20 each
• Lateral links $10 each
• Trailing arms $40 set
• Endlinks $20 set
• Steering Rack $75
• Power Steering Lines $25
• ABS Module $40
• ABS Sensors $15 each
• Brake Master $30
• Brake Booster $30
• Front Brake Calipers $25 each
• Proportioning Valve $20
• Clutch Master $30
• Clutch Slave $30
• Airbox $30
• Crankshaft Pulley $30
• Plug Wires $30
• Air Assist Injector $35
• Timing Covers $10 each
• Power Steering Pump with reservoir $75
• Power Steering Pump Bracket $10
• AC Compressor $80
• AC Compressor Bracket $10
• AC Tensioner $25
• AC Lines $30 each
• Alternator $65
• Fuse Box $25
• Wiper Motor $30
• Fuel pump $20
• Washer Fluid Tank $15
• Pitch stop mount $10
• Gas cap $10
• Oil dipstick $10
• Oil cap $5
• Oil fill neck $5
• Radiator Mounts $10
• Alternator Cover $5
Exterior
• Headlights $50 each
• Corner Lights $20 each
• Taillights $50 each
• Fog Lights $20 each
• Headlight Trim $15 each
• Taillight Trim $15 each
• Doors $100 each
• Hood $100
• Fenders $75 each
• Front Bumper (No Lip) $50
• Front Bumper Beam $50
• Grill $40
• Rear Bumper $75
• Rear Bumper Beam $50
• Hatch $100
• Sideskirts $50 set
• Mirrors $25 each
• Wiper Arms $30
• Trim/Weatherstripping $10+
Interior
• ECU $50
• Bulkhead Main Harness $75
• Fuse Box $25
• Gas, Brake and Clutch Pedal Assembly $75
• Cluster $50
• Dash $70
• Glove Box $30
• Steering Wheel w/Airbag $75
• Passenger Airbag $40
• Seatbelts $40 each
• Steering Column $50
• Key set: Ignition, Locks and Key $50
• Center Dash Cubby $40
• Center Console $50
• Shifter Surround, Boot & Knob $30
• Door Cards $25 each
• Front Heated Seats $80
• Rear Seats $40
• 6 Disc CD Player $40
• HVAC Controls $40
• Heater Core $60
• Blower Motor $50
• Auto Dimming Rear View Mirror w/Compass & Temperature $40
• Dome Light w/Clock $40
• Map Light $15
• Headlight Switch $25
• Wiper Switch $25
• Master Switch $25
• Window Switch $10
• Door Lock Switch $10
• Mirror Switch $10
• Cruise Switch $10
• Fog Light Switch $10
• Rear Wiper Switch $10
• Heated Seat Switch $10
• Interior Plastic Pieces $10+
More pics:
