Garage Sale - WRX, STi, LGT, FXT, etc...
LiftedWRX
WV
Mostly GD WRX & STi parts but some FXT, LGT & RS parts as well.
Located in Fairmont WV or shipping isn't a problem just message me for a quote. If you want pictures of a certain part or interested in something not listed just ask.
04/05 FXT Pics: • 4.44 Transmission $750
• 4.44 Rear Differential $200
• Manual Driveshaft $50
• Clutch Slave Cylinder $30
• Clutch Line $15
• Clutch Fork $20
• Clutch Fork Rod $20
• Intake Manifold $100
• DBW Throttle Body with MAP $100
• Side Feed TGVs $75
• 555cc Yellow Side Feed Injectors $100
• 04 & 05 Steering Wheels with Airbag and Cruise Switch $100 each
• Rear Crossmember $150
• Control Arms $25 each
• Sway Bars $25 each
• Front sway bar mounts $10
• Rear sway bar mounts $10
• Center differential $200
• Front differential $150
• 5 speed transmission case $100
• Gear Shaft $75
• 6 Disc $25 (one speaker channel doesn't work)
05 LGT Pics: • Intake manifold $50
• Engine harness $50
• Side feed fuel lines $50
• Gauges auto $50
• ECU auto #22611AJ18B $50
• MAF #22680AA31A $35
• BPV hose $5
• Airbox lid $5
• Intake pressure sensor #22012AA160 $5
• Boost solenoid controller $25
04 Impreza RS
• SOHC Complete Heads $200
• Plastic Intake Manifold $100
• Throttle Body $60
• Fuel Lines $40
• Engine Harness $50
• Crankshaft Pulley $30
• Injectors $40
• Air Assist Injector $35
• Fuel Pressure Regulator $35
• Plug wires $30 set
• Fuel Rail Covers $10 each
• Timing Covers $10 each
GD WRX & STi Parts
Engine & Drivetrain Pics: • JDM EJ20X Longblock (less than 60k miles) $1,500
• PE1820 Turbo - Upgraded VF30 $700
• DW300 Fuel Pump $75
• Fuel Pump Hanger $75
• Fuel Pump Controller $50
• 04 STi Engine Harness $100
• 04 STi Bulkhead Harness $200
• 04 STi Cluster Harness $50
• 04 STi ECU #8J 22611AJ241 $200
• Coilpacks #FK1086 $50 each
• MAF Sensor #22680AA310 $25
• 04 STi Clutch & Brake Pedal Assembly $75
• 04 STi DBW Gas Pedal #36010FE020 $50
• Catless Aftermarket Uppipe $100
• 04 WRX Axles $100
• 04 WRX Driveshaft $100
• Delrin Black Teardrop Shift Knob $25
• 2 Button Key Fob Remote #88036AE060 $20
• 06 STi 5x114 Passenger Front Knuckle $100 (34k miles)
• 06 STi rear axles $100 each (34k miles)
• 06 WRX front axles $75 each
• New Stainless Steel Clutch Line #SUBCL-115 $20
• 06 WRX Brake and Clutch Pedal Assembly $75
• 06 WRX ABS Module $50
• 06 WRX Proportioning Valve $20
• Cam Gears: #13320AA000, #13320AA001, #13321AA001, #13322AA000, #13322AA001 & #13323AA001 $100 each
• Water Pump $25
• Oil Pump $50
• EJ20 valve covers $40 set
• STi front axle without outer CV $30
• STi clutch master $40
• STi side feed fuel rails with line $50 set
• STi passenger side feed fuel rail with line $25
• Side feed TGVs $75 set
• Purge valve $10
• Purge valve solenoid $25
• STi proportioning valve $20
• Boost solenoid controller bracket $5
• Radiator mounts $10 set
• Power steering reservoir $20
• Power steering reservoir bracket #34633FE001 $5
• 04 WRX steering column $50
• 04 STi steering column with ignition, key $100
• 06 STi steering column with ignition, key $100
• Transmission mount $20
• AC compressor $80 #73110AE021
• AC condenser $50
• Passenger radiator fan $25
• Radiator coolant hard line $10
• Manifold coolant hard line $10
• Water temperature sensor $10
• Oil dipstick $10
• TMIC hard lines $10
• Oil cap $5
• Oil cap with fill neck $10
• 02-05 WRX cruise control actuator module $20
• Hood prop $5
• Battery tray $5
• Turbo uppipe bracket $5
• Pitch Stop $10
• Left, Right & Center Outer Timing Covers $15 each
• Front O2 sensor plastic cover $5
• AC Lines $25+
Suspension,Wheels, Tires, & Brakes Pics: Rota Gforce 17x8 +48 Wheels with 225/45 General Altimax Artic Tires $800
• 04 WRX Struts & Springs 86k $300
• 04 WRX Front Knuckles $100
• 04 WRX Sway bars $25
• Rear Aftermarket Endlinks $25
• Front Aftermarket Endlinks $25
• 04 WRX Trailing Arms with Brackets $40
• 04 WRX Front Calipers $75
• 04 WRX Front Rotors $25
• 04 WRX Rear Rotors $25
• 04 WRX Brake Master Cylinder $25
• 04 WRX Brake Booster $50
• WRX STi ABS module #27534FE270 $40
• ABS Sensors: #27540AE000, #27540AE001, #27540AE010 & #27540FE040 $20 each
• 5x114 rotors were turned and never used $50
Exterior Pics: • 04 WRX Headlights HID Retrofit Plug N Play $300
• 04 WRX Taillights $250
• 04 WRX PSM Hood $250
• 04 WRX PSM Front Bumper $250
• 04 WRX Front Bumper Beam $100
• 04 WRX PSM Rear Bumper $250
• 04 WRX Rear Bumper Beam $100
• 04 WRX PSM Trunk with Wing $200
• 04 WRX PSM Side Skirts $125
• 04 WRX Grille $50
• 04 WRX Headlight Brackets $20
• 06 CGM WRX Driver Fender $150
• 06 CGM WRX Trunk & Wing $200
• Driver rear exterior door handle PSM $20
• Wiper arms $30
• Passenger mirror CGM $25
• Driver mirror no cover black (TR WRX) $25
• Gas lid PSM $10
• Exterior B pillar molding $15 each
• GD Rear PSM & Doors $150 each
Interior Pics: GD Interior Parts
• 04 WRX Front Seats $400
• 04 WRX Rear Seats $200
• 04 WRX Door Cards $50 each
• 04 WRX Carpet $100
• 04 WRX Dash $100
• 04 WRX Center Console w/STi Shifter Surround $125
• 04 WRX Gauge Cluster 86k Miles $100
• 06 WRX Gauge Cluster 133k Miles $100
• 04 WRX Steering Column $100
• 04 WRX Steering Knuckle Linkage U-Joint $40
• 04 WRX Clock Spring #83116SA010 $50
• 04 WRX Ignition with STi Key & Light $75
• 04 STi HVAC Controls $40
• 04 WRX Radio & HVAC Surround Trim $20
• 04 WRX Center Air Vents with Hazard Switch $30
• 04 WRX Auto Dimming Rear View Mirror $40
• Cluster Surround $20
• Subaru Tool Kit #97010FE040 $20
• Map Light $25
• Dome Light $20
• 3rd Brake Light $20
• Visors $50
• Visor clips $5 set
• Center rear view mirror sun visor $10
• Interior mirror cover right #94251FE000 $5
• Interior upper B pillar trim $10 each
• Interior lower B pillar trim $10 each
• Interior C pillar trim $10 each
• Rear seat trim $10 each
• Trunk latch trim $10
• Door kick molding trim $10 each
• Driver center console side cover $10
• Rear heat vents $10
• Seat belts $40 each
• Seat belt buckles $10 each
• Trunk release cable $10
• Gas lid release cable $10
• WRX trunk hinges $20
• WRX torsion bars $20
• Weatherstripping: Doors, hood and trunk available $5 each
• Fuel pump cover $5
• Jack $5
• Trunk left and right liners $25
• Rear dash $40
• Bugeye door cards $50
Electronics Pics: GD Electronics
• Kenwood 4 Channel Amp #KAC-8402 $50
• 4x 6 3/4" Kenwood Speakers #KFC-P709PS $80
• 05-07 mirror switch $10
• 02-04 mirror switch $10
• Hazard switch $10
• Engine bay fuse box $25
• Rear view mirror wire cover $5
• Map light $20
• Dome light $20
• 04 STi ignition & key $40
• 06 STi ignition & key $40
• Headlight/blinker switch $25
• Wiper switch $25
• OEM horns $5 (2 available)
• ECU cover $10
• Wiper motor $40
• Positive battery terminal cable $5
• 04/05 WRX fuel tank wiring $20
• DRL module #84067FE060 $10
• DRL module #84067fe000 $10
• 04/05 control unit air bag #98221FE110 $40 (2 available)
• 06/07 control unit air bag #98221FE220 $40
• WRX STI left front air bag sensor #98231FE070 $10 (2 available)
• WRX STI right front air bag sensor #98231FE060 $10 (2 available)
• WRX STI left side airbag sensor #98235FE150 $10 (2 available)
• WRX STI right side airbag sensor #98235FE140 $10 (2 available)
• WRX STI left side airbag sensor #98231FE010 $10
• WRX STI right side airbag sensor #98231FE000 $10
• Airbag harness $25
• WRX STI G Sensor ABS #27540FA022 $10
• WRX STI G Sensor ABS #27540FE090 $10
• Fuel injector resistor module #684227 $10 (2 available)
• Door ajar sensors $20 set of 4 (2 sets available)
• 04/05 WRX STi keyless entry module #88035FE140 $20
• 04/05 WRX STi keyless entry module #88035FE141 $20
• 06/07 WRX STi keyless entry module #88035FE190 $20
• 04/05 WRX STi integrated control module #88281FE160 $20
• 06/07 WRX STi integrated control module #88281FE340 $20
• WRX STI clarion antenna amplifier assembly #86327FE090 $20
More Pictures:
LiftedWRX
WV
OP updated with a ton of parts and added a link to new pictures of individual parts after the list
LiftedWRX
WV
Updated the first couple of posts with new pictures and parts list.
Links to albums of more pictures are located beside each group of parts
