GateFinder
Does anyone happen to know if you can install the shock/struts from an Outback Wilderness on an SK?
That’s very good info, thank you!Yes lots cool stuff rly out there between models . Like obk bp in front can be slightly lifted just with sh forester front strut. As its about 15mm higher.
Or like in reat if you going for 10 cm and more lift its e34 bmw rear struts are like 10 cm higher. Could use bmw strut and merc spring and subaru mount. Lots stuff out there that really works so you dont need like custom made things if you search
