marvellous_matt
HI,
Long story short the speedo has stopped working on my 04 forester X with 165k on the clock. Unfortunately it is not the speedo sender unit($190), so I believe it must be the nylon gear with in the gearbox that drives the sender unit. SO it is a gearbox out and spit open job, more work than I am prepared to undertake I think.
I do want to change the gearbox oil and see if there is anything in there that might confirm my suspissions. Ive found what I think is the oil drain plug however it has a funny star shape in there and im not sure what I should use to open it. Any one have some suggestions?
I also want to confirm that the volume of oil in a manula is 3.5 litres. I have 4 L and Im along way from the shops if this is not enough.
thanks for any help you can offer.
Matt
Matt
