Phew!.....I did wonder what was offensive, and why it had vanishedVery kool @Davo
New thread created as I don't want this great idea to get lost
Would it be possible to put one of the panels in reverse, e.g have one panel as per your setup and have the 2nd one extend out the rear. I am not familiar with the space beneath the roof bars.I should add...if you were doing double stacked solar panels, you would need to attach them on top of the bars (or have a smaller top panel that sat only in the space between the bars). The shadow from the roof bars would smash the solar output from the top panel
Much simpler! Interestingly, the rails on my '11 are till further apart at the front than the back. I took my initial measurements at the back, assuming the rails were parallel! Nope!On earlier models with those strange roof rails that are further apart at the front than they are at the rear and that have a recess on the inner side it is possible to screw a length of aluminium angle section to an appropriate width solar panel so as to be able to slide the solar panel to fit neatly into the recesses.
Worked very well on my MY03 with just enough space to fit the cross bars and roof coffin in front of the panel thus preventing it from moving as well.
Obviously a smaller panel than Davo`s would be used. In my case a 50 watt one was used but there was/is room for a larger one.
