odis.22
- Mar 28, 2021
- 5
- Queensland
- 2006
- Forester
- Manual
What is the largest legal tires in QLD Australia that I can fit from the stock ones (215x60R16)?
Not that it's really relevant to this conversation, but from my research any car can have up to 50mm lift in QLD, not just MC classified vehicles.The ADRs regard a small lift kit (up to 50mm) as an "owner certified modification", ie, no approval or mod plate or engineer’s certificate is required
So the 43mm is technically under the 25mm limit as you were saying the diameter is double the tyre lift?
Oh yeah that makes sense,Not that it's really relevant to this conversation, but from my research any car can have up to 50mm lift in QLD, not just MC classified vehicles.
I wish cars in QLD were allowed a 50mm wheel diameter increase.![]()
Dont need it to fit there... getting a custom wheel and jerry can holder on the back.... gonna use that space for something else215/70/16 Does not fit in the spare tyre space in a 2005 forester. Diameter is too big to fit.
The 215/70/16 made my Speedo read exactly correct instead of reading slow with standard 215/60/16. Speed and GPS speed on Google maps Aligned perfectly.How does all that affect the odometer and speedometer in a practical sense?
Would bigger tyres mean I went further and faster than what the odometer and speedometer tells me?
I have 215X65X16 tyres and the speedo is about spot on per the `phone GPS and also those road speed check 5 km sections.
Indeed you need to deflate your tyre to fit in the existing well and also cutting away some of the foam helps.
Yes. Your service intervals should also be shorter, if you go by the odometer.Would bigger tyres mean I went further and faster than what the odometer and speedometer tells me?
Normally the standard tyres make your speedo read fast to avoid you exceeding the speed limit. Is that what you mean perhaps?The 215/70/16 made my Speedo read exactly correct instead of reading slow with standard 215/60/16. Speed and GPS speed on Google maps Aligned perfectly.
Usually yes depending upon manufacturer`s calibration.How does all that affect the odometer and speedometer in a practical sense?
