stephendean
- Jul 11, 2008
- 217
- Salisbury SA
- 2018
- Outback
- auto
Proof that Subbies go anywhere - almost
[media]
[media]
I reckon you're heading in the right direction then.Since I last was on this forum I've left my job in Sydney and moved to Bathurst,
from what ive read & watched on youtube the CVT cuts power when there is too much load on itabout the video, was the diesel a CVT? I'm surprised it didn't go as far as the XT
Yes, the SJ diesel has a CVT, and the owner has already come to the conclusion that if he could swap it for a traditional auto box he'd "do it in a heartbeat". As for it not going as far as the SH XT... he got the locker installed after doing a couple of trips with me and he found he just couldn't climb the obstacles I could with mine. He put the rear Torq locker in recently and, while it's a whole lot better, it's now the CVT gearbox that still lets it down.I reckon you're heading in the right direction then.Big Cities are overrated. Even small cities are...
Yes, you're right. As the SJ diesel owner and I have found on our journeys and testing, the CVT warms up very quickly and is generally shutdown by the computers, even without warning or codes. The day after this trip he went back to his engine tuner and had them tweak a few things, including the drive split to the rear, which he hopes will help it push a lot further offroad. I just installed a center diff lock circuit in my SH and I'm testing it in comparison to just letting the factory computer setup do its thing.... which is quite good. The videos from Lidsdale show that it's not sending much power to the rear until the front slips and even then it's not for long. My new circuit is adjustable and I hope to set it up so I can ramp up power to the center diff lock (duty solenoid) and get it pushing a lot harder from the rear. Meantime, my auto box has a trans cooler from a Pajero on it and I bypassed the lines going through the radiator to help keep everything cooler when working hard. David, who owns the SJ diesel, is going to do the same when he can.from what ive read & watched on youtube the CVT cuts power when there is too much load on it
Yeah, that's what I was inferring. Seems a bit of a waste to attach a CVT to a diesel.from what ive read & watched on youtube the CVT cuts power when there is too much load on it
Interesting. The general feel I get from researching the auto in my SVX is that it's better to use both in line, run it through the factory oil cooler, then the external cooler and back to the engine.Meantime, my auto box has a trans cooler from a Pajero on it and I bypassed the lines going through the radiator to help keep everything cooler when working hard.
I've actually been thinking of doing a thermostat delete for that very reason! Don't really see the point up here, just a restriction to flowNo point where you are Ben!
Reminds me that I have wanted to divert mine away from the radiator and go directly to / from the external cooler.
