FurryMoses
New Member
I know the answer is partly "yes"... but I need help.
I just fitted the standard sized tyre (225/60/R17) to my "space saving" steel rim.
I actually got Maxxis AT771 - https://www.tyrereview.com.au/maxxis-bravo-at771-long-term-review
The "space saving" steel rim, explicitly says not to drive over 80km/ph and travel only 100km (? can't remember)
I just wanted to ask you guys, surely this is only a limitation of the "standard" actual space-saving tire size - which is 185/65/R17?
Presumably, now I've fitted a normal sized (225/60/R17) to this steel rim, all the warnings can be ignored?
PS I'm planning to buy an alloy wheel, the same as the other 4 to fix this, but in the meantime...
