simxs
Had a bit(!) of a problem with my clutch a few weeks back. All of a sudden, the clutch would only partially engage (4000rpm for 60km/h in 4th gear) and wouldn't fully disengage when the pedal was pushed. Luckily this happened only a few suburbs away from home and my local mechanic's shop.
The NRMA organised a tow truck to the workshop (mechanic was rather surprosed to see me again so soon after having fitted new tyres and starter) and I left the car with them to fit a new Exedy clutch and solid flywheel in place of the OEM dual-mass (ie squeaky) unit.
$2200 later the car was drivable again although there is more vibration through the drive train at low revs under load with the solid flywheel. Clutch pedal is much lighter and the engagement point is higher but more sudden - it's taken a bit of getting used to.
They binned my old flywheel so I didn't get a look at it but attached is a pic of the old clutch, including pressure plate broken into three pieces!
