Draw sizes
Ser_Egg
Subaru Forester SG series 1
5Spd Manual
I have been lookinng at putting some draws in the back of my SG. I am wondering what size can i fit in
I can measure mine tomorrow but you should probably measure the space yourself to be sure ;)
Does 215/65/r16 fit in spare wheel well?? Ive read up on your post on subaruforester.org. i reckon i could do exactly what they did for you. How did they mount that steel bar. Is bolted in where the cargo hooks would be??
Yes, the 21565r16 does fit - you may need to "modify" the wheel well a little; I found a 4x2 and a lump hammer did the job ;-)
The steel bar is bolted to the cargo hook location; but after it failed I changed mine to gate hinges bolted to the floor.
C'mon peop[e, it's drawers for <insert favourite dietie's place of residence here> sake!
On the topic of drawers, what do you do with the spare wheel well? kinda hard to get to with drawers on top isn't it?
Yes, yes they do. A little deflation is all that's required I found.
mmm i may skip the the hinge part, cut out a flat board and put the DRAWERS ontop of that. Hell if im already doing that i might as well design my own set of DRAWERS while im at it
P.S. @Ben Up North fixed the DRAWERS ;)
But how do you get the spare out with the drawers in (without a lot of bother)?
In my case it's the second spare under the drawers so not an issue
