baipin
- May 16, 2020
- 11
- Ontario, Canada
- 2017
- Forester
- CVT
I'm looking to fab my own trailer (it's by far the cheapest option for me - and the most fun)! It'll do double duty as an overland trailer and utility trailer, since I do a lot of river cleanups and community gardening/helping a friend build a homestead.
I don't expect to tow more than 500-1500lbs on the regular, but from everything I've read, the Forester can safely tow up to 4409lbs (2000kg) so long as the trailer is braked and you keep your speed low (this is a UK rating, where lower towing speeds are legally mandated). To my knowledge the UK and Canadian Foresters are the same, except the UK have a transmission cooler, stronger hitch (my DIY hitch/rear tire gate was build to this spec) and possibly higher spring rate in the rear. I don't suppose there'd be something completely different with the unibody or suspension that'd make towing more with the USDM foz impossible? Being stuck with 1500 lbs when international Foresters are rated for nearly triple is a bit underwhelming...
So basically, does it make sense to build a trailer that could tow 3500lbs, even if I do that very rarely, or is that just a bad idea with the Canadian version of the Forester XT, and thus it makes no sense over-building it?
