SubyForester
Lots of questions...
Looks like my recently acquired 2008 forester x auto (MY09) has head gasket leaks. I knew I had to do the timing belt and front control arm bushes but what a pain... wanted to spend money on suspension and lift kits. Ah well. I’m hoping to monitor the leaks and keep driving it for a bit until I get all the parts together. Budgeting up to $1k for bits/head servicing. Is this realistic? Can anyone tell me if it’s possible to change the HGs without pulling the motor out? Have seen it done engine in with an older outback. Or is it just easier to pull the motor to do it?
Anything missing from this parts list? Anything that’s extravagant?
- Full engine gasket set (with MLS head gaskets - recommended brand?)
- copper head sealant stuff - recommended or not?
- gates/dayco/aisin timing belt/tensioners/water pump kit and thermostat
- set of head bolts
- coolant
- oil and filter
- spark plugs
- assembly lube - reassembling the heads.
- Perth (Australia) based machining shop for heads - any recommendations?
- cleaning materials - mineral turps, brake cleaner, scraper.
- are any special tools required? I have an engine hoist, car ramps, jack, axle stands, standard metric and torx sockets, torque wrench, an angle gauge for the head bolts and will get a cam pulley holder tool and maybe an engine stand.
- set of head bolts
- coolant
- oil and filter
- spark plugs
