El_Freddo
- Aug 11, 2008
- 2,399
- Bridgewater, Vic
- 1988, 1990
- EJ22'd L series; Targa Brumby
- Locking FT4wd 5spd Manual, 4.111:1 diff w 1.59:1 low range & front OBX LSD ;)
G'day all!
Few of you know that I'm soon to drop an EJ into my L series. I've been gathering parts for the last 9 months or so, playing with wiring during that time and am now playing with some gearboxes (I'll get into that later).
So I started with some wiring, it looked like this when I got it:
After a few sessions of getting my head around the wiring, and with some help of a wiring diagram or two I ended up with this:
^ The EJ harness that I need is on the right, the stuff I don't need is on the left
I have set up my EJ22 in the shed on the floor to give it a run before I pull Ruby Scoo (my daily driver) off the road to fit it. Yesterday I hooked up my cut down loom, got a radiator, battery and fuel sorted, this was the result:
[ame="https://www.youtube.com/watch?v=CUjKbPrZDLM"]YouTube - EJ first test run[/ame]
I was very happy with the result. I now have a tacho working but do not have a temp guage to reference yet - I want to run it for a while to see if I get any codes - I've already got a code 11, something I'll have to find out what it means...
Today I split a dual range EA 4wd gearbox and an EJ AWD dual range box. What I'm aiming to achieve here is Part Time 4wd EA running gear with an EJ casing - this will get around needing an adaptor plate while retaining the original ratios and mounting points so no further modifications needed to Ruby Scoo with exception of the crossmember that will need to be slotted to allow the motor to bolt in.
I just need to sort the diff backlash properly and I should have a goer on my hands (gearbox wise). Then its a case of sorting the wiring into the L and do the mechanical swap. I've also got to get my custom radiator modified to take the 40mm EJ hoses...
Progress might be a little slow from here, I have a few large jobs to complete - and hopefully I don't need to do the head gaskets... Time will tell.
